calloway
Old Nov 20, 2003 | 10:02 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
calloway
Does anyone know what computer and prom this would possibly use?
http://www.motorsportsdigest.com/features/cway-02.jpg
Old Nov 21, 2003 | 08:56 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
First, this thing has intercoolers, so the first thing to figure out is if has a power adder, or if it running them on a n/a engine.
Old Nov 21, 2003 | 09:00 AM
Okay, I went and found it, this is the TwinTurbo Callaway car, not many people would purchase intercoolers if they were not boosting.
Are you plannig on running turbos? If so, I think the best to do is tune it yourself, seeing as every tune is different.
If you are not planning on boosting, then I wouldn't worry about it, because the tune will not run near perfect in a n/a engine.
http://www.motorsportsdigest.com/cars2.htm
Old Nov 21, 2003 | 01:14 PM
shaggy56's Avatar
Car: 71 Nova
I guess I was really wondering how difficult a project like this would be to pursue. It would be nice if someone had technical info on this engine. Like block type, pistons cam etc. I know it wouldnt be cheap but what is.
Old Nov 21, 2003 | 04:02 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: calloway
With two intakes, due to the two intercoolers, I'd say it would have to me a SD system. Looks like their old Sledge Hammer. Calloway has always had some ties to GM so I'd imagine it has a 1227749 Syclone ecm in it. If the vette is 89-90 or earlier it'd be had to say what they may have used.
I'm sure the prom was done on a dyno, and is a one-off.
Old Nov 21, 2003 | 06:37 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
The Callaway Twin Turbo Corvettes (RPO: B2K) used the same '165 ECM and $32b code that the 86-88 Corvettes used. There was also a microfueler computer installed under the driver's hush panel that controlled 2 extra injectors placed in front of the throttlebody.
Old Nov 21, 2003 | 07:34 PM
shaggy56's Avatar
Car: 71 Nova
If it did why dont i see a maf or am i missing something.
Old Nov 21, 2003 | 08:02 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
You're missing something! Take a look here: http://www.motorsportsdigest.com/cars2.htm
You can clearly see the MAF in front of the engine in one of the pics.....
Old Nov 21, 2003 | 08:29 PM
shaggy56's Avatar
Car: 71 Nova
Are the parts stock? Did they just remove the screens or something. Anyone know the engine specs? I have that exact ecm and maf. I see this has been thought of before. I would imagine it would be possible with a 7730 as well.
Old Nov 21, 2003 | 09:11 PM
scorp508's Avatar
Car: Corvettes
There is a ton of research and work in that setup.
I highly suggest you go here...
http://www.corvetteactioncenter.com/...s=&forumid=134
....that is a forum dedicated strictly to Callaway Corvettes with many extremely knowledgable owners. Good luck.
Old Nov 21, 2003 | 09:48 PM
shaggy56's Avatar
Car: 71 Nova
I found a tech break down of the engine. Its the sledgehammer though.
http://www.madwheels.com/sledgehammer/
Old Nov 22, 2003 | 11:37 AM
shaggy56's Avatar
Car: 71 Nova
I found an exact replacement for that turbo online for $569. Thats the same one the 1987 callaway engine used. Made by Warner ISHI. The garret that probably produce alot more power are about $900 each. I see a pair on ebay for $500.
Old Nov 22, 2003 | 11:46 AM
scorp508's Avatar
Car: Corvettes
What is your goal?
Old Nov 22, 2003 | 12:24 PM
shaggy56's Avatar
Car: 71 Nova
Just an idea in the back of my mind. Maybe one day when i accumilate the parts i can make it happen. I have a 383 stroke i built for now. Maybe when this project ends it may be something to juggle around a while with. Im thinking 5 speed (if it can handle it) and the dual turbo as well as a twin intercooler with hardened aftermarket parts.
pacman63
Dec 8, 2011 09:00 PM
Tim Burgess
Aug 21, 2001 06:38 PM
