950 ECU base maps
Old Dec 3, 2003 | 11:54 AM
Ringmaster72's Avatar
Car: 1989 IROC
950 ECU base maps
I finally got my car running over the weekend, but then I was out of time and had to come back to Maryland so it is not tuned yet. My question is: Can anybody with the 950 send me their base maps that have similar setups? I would like to have someone that I know has a working tuned car as comparison to Holley's base maps just so I have more to look at. I just think it would make it easier to have a base map to look at, which I am sure is working properly. When I finally got the car running this weekend it ran fine sitting still, but once i took it down the road, it was not smooth and was jerking a lot. I am pretty sure that it is due to the timing of the engine not being synchronised with the ECU, at least I hope that was the problem.
Tim
Old Dec 8, 2003 | 03:39 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
My old combo was similar to yours. I started out with the ZZ4/stealth ram map from Holleys website & tweaked it from there. The HSR likes a lot of timing advance, at least in my case. The Holley maps are usually rich. I guess they want to err on the side of caution so you don't melt a piston.
KO1
16
Oct 15, 2015 05:00 PM
bjpotter
Oct 4, 2015 07:48 PM
aaron7
Sep 30, 2015 09:15 AM
ndndndnd
Sep 28, 2015 08:00 AM
