code 53 & no start
Old Jan 4, 2004 | 02:34 PM
renegade313's Avatar
Car: 92 RS
Engine: STOCK
Transmission: SEE ABOVE
code 53 & no start
..guy`s I`m tring to track down the pass key decoder module,I have literlly stripped this dash tring to find. Alldatas photo`s aren`t any help.Has anyone replaced one? A picture and good location would really be appreciated. it`s a `92 RS VIN"E"305 THANKS ROBERT
Old Jan 4, 2004 | 07:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I have a little package that I will e-mail to you concerning this if you want it. By the way, what leads you to believe that you have a problem with the VATS control module? It's located behind the dash just above the a/c control unit and to the side.
PS: Code 53 only indicates that there is a voltage at the ECM ignition input pin that is greater than 17.1 volts for 2 seconds. I would be checking the battery and alternator first. If you had a code 46, then you could worry about the VATS system.
The Trickster!!!!!!!!!
Old Jan 4, 2004 | 09:15 PM
Car: 92 RS
Engine: STOCK
..thanks for the help TRICKSTER.Maybe I quoted the wrong code #,but after jumping the start cutout relay I was able to get starter function back,but still no fuel,I DID FIND THE MODULE , THIS WAS TOTALLY ABSURD WHERE IT WAS PUT BUT I GUESS IF IT WAS EASY...I would apprecaite any help you might have. Alldata has a problem tree I` ll go through in the morning to see whats going on.Called chevy friday just for a price 220 bucks...
Old Jan 4, 2004 | 09:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I have the trouble tree from the GM service manual that I can e-mail you. Also, it might not be the module that is the problem anyway. They very seldom if ever go bad, it is usually the ignition lock cylinder or the key. Give me some more specifics on your problem.
The Trickster!!!!!!!!!!
Old Jan 4, 2004 | 09:37 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You have e-mail!!!!!!!!!!!
The Trickster!!!!!!!!!!!
Old Jan 4, 2004 | 09:53 PM
Car: 92 RS
Engine: STOCK
the problem came out of nowhere,no warning,just no start,tried all my ing. keys,everything appears fine,turn the key ..nothing, used a code checker, thought it was 53, maybe not, but it for sure pointed me to ck the vats sys.I remove the breather poured a little gas in,(with starter disable relay "jumped")car did start.T he only thing I cant say for sure is what the SECURITY light was doing.ck`d starter,battery,neutrel safty switch,dropped ing.switch,tested out ok,all fuses,but I`ll ck the rest in the moring now that I have access to EVERYTHING I have had this car 11yrs so maybe the pads in the lock asmy. just gave up the ghost?Its just so strange that it gave no warning,today it was fine then tomorrow not`a...
Old Jan 4, 2004 | 10:15 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Do this simple little test for me, take a multimeter and set it to OHM's. touch the probes to the contacts on the key and measure the resistance. Next put the key in the ignition lock cylinder in the off position. Disconnect the ignition lock cylinder wire harness connector under the dash. Now take the multimeter, still set at OHM's and try to measure the resistance value of the key through the harness connectors. If you can't, the problem is in the Igniton lock assembly or the key is worn.
Old Jan 5, 2004 | 07:25 PM
Car: 92 RS
Engine: STOCK
..yeap trickster your gut was right ,one of the wires was broke right at the end of the lock barrel asmy, soldered them back togetter,a little heat shrink,time will tell. many thanks!!!!ROBERT
Old Jan 5, 2004 | 07:38 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Glad to hear that things worked out okay and hey, look at the bright side. You now have a better perspective of where things are under your dash J/K
The Trickster!!!!!!!!!!!!
Old Jan 5, 2004 | 08:00 PM
Car: 92 RS
Engine: STOCK
THATS A NO TRICK..noticed ya work on the winged varitiy of vehicles,I dabbled abit in aviation myself,but as you all well know a/p mechanics are not in great demand right now.So now I drive a truck... Still turn wrenches but only as a hobby,of sorts,got this 92 as a daliy driver and a 86, 87, for parts and other.... any ideas ya`ll :werd: thought about a J-57 IN THE TRUNK AND RUNNING THE SILVER STATE, JUST NOT SURE ABOUT THE FUEL CUNSUMPTION AND THE 90 MILES
Old Jan 5, 2004 | 08:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I had thought about putting a J-79 with A/B in the trunk and a large tank where the back seat was. The idea was going great until somebody mentioned brakes. But you are right, A/P mechaniics aren't exactly in great demand at the moment and when they are, nobody wants to pay them anything. Hopefully, this new company that's moving to the old air base at Myrtle Beach will get things going soon.
BTW, what part of North Cack-a-lackey are you in.
Old Jan 6, 2004 | 07:51 AM
Car: 92 RS
Engine: STOCK
..uuh brakes, mmm didnt think about those see thats why you get the big bucks :hail: I did try to scoung a couple of JATO bottles while in the AF but could`nt find any probably a good thing all I had at the time was 67 RS,hate to have made the 6 o`clock still got the 67 thats another project, Home is alittle town called Haw R iver,just outside of Burlington,but way things are growing these days you run from one town to another so fast ya need a navigator. It used to be pretty rual, but with us so close to 40/85 thats long over....got`s to git the wild and wonderful is calling (WVA)...again many thanks ! Robert
Orr89RocZ
Apr 25, 2016 08:28 AM
mizz0313
Aug 12, 2015 06:45 AM
apie2546
Aug 10, 2015 05:43 PM
