DFI with supercharger
Old Jan 27, 2004 | 08:59 PM
yellow87irocz's Avatar
i have an 87 iroc that i am putting a healthy SBC in and i am using a 88 serpentine belt setup and running an ATI D-1
anyways i am going to ditch the TPI setup and want to convert my victor jr intake into a multi-point FI setup but i need to know what brands of DFI will work with what i am wanting to do
thanks for the help
Old Jan 28, 2004 | 08:11 PM
biggtime's Avatar
I use a accel DFIV7 on my boosted cutlass with a HSR. I also am in the process of putting one in my Typhoon with a intake I made.
Old Jan 28, 2004 | 08:14 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: DFI with supercharger
thanks for the help
Actually I'd recommend an OEM GM ECM: the 1227749 or the 1227730 running the $58 mask. This mask will run in either ECM and as is will handle up to 1 bar of boost (14.7PSI). The $58 mask is the EPROM bin and was used in several GM turbo vehicles including the Typhoons and Syclones.
RBob.
Old Jan 29, 2004 | 02:44 PM
biggtime's Avatar
I do not know that much about stock GM computers, but if he runs more than 14.7 psi with that D-1 the 2 bar map will not work and he will have to go with a 3 bar (as most of us sy-ty guys do) will that $58 mask work with a 3 bar setup?
Old Jan 29, 2004 | 03:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
With a code patch the $58 code will work with a 3 bar MAP. I've heard rumors of a patch out there in the public, but have not seen it.
RBob.
Old Jan 29, 2004 | 05:28 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Overshooting the rating of the sensor slightly isn't a big deal, unless your Pro Racing.
To say you need to run a 3 bar MAP, on a car running 15 PSI is more harmful then good, IMO. Why use a sensor the gives 1/3 resolution to gain resolution to run an increase of .3 PSI?.
There are alot more important issues that folks tend to ignore.
Old Jan 29, 2004 | 05:32 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
How healthy?.
How high of RPM are you going to spin it?.
S/C is much different the running N/A. Saturn5, had a TPI with S/Cs running really well, blowing thur the TPI.
Old Jan 29, 2004 | 09:04 PM
lets just say
it has canfield 220 heads a mechanical roller cam(.575/.590) lift and it has been stroked
the cam has been designed for a D-1 on 25# of boost
this is a race car that can be driven somewhat on the street but i want a DFI kit not anything by GM (GM didnt make the car with supercharger so they didnt intend for one to be on there with FI)
and i want a DFI cuz i am completely gutting the car and re-wiring it
Old Jan 30, 2004 | 08:24 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
lets just say
on a slight side note..... HI, im in charleston too... itd be cool to check out your setup sometime..
im doing something similar, and considering aftermarket DFI too. soild roller 400 with a eaton M112.
all of the current aftermarket setups ive seen support boost, so you're mostly looking at the other features.
if you can afford it, the Accel DFI VII is the best out there that ive seen... on the cheaper but still fully functional side is the holley Commander 950.
dont go off thinking the GM 749 isnt a very capable system.. the learning curve is a lil steeper but it is a fully functional, cheaper option.
Old Jan 31, 2004 | 11:45 PM
travis we didnt really talk about it on sat when i met up with you in N-Chas
but i will talk to you more about it when i see you
Old Feb 2, 2004 | 08:54 PM
well my friend mr.dude here
has swayed my mind and got me interested in this 749 ecm and mask so can someone give me more info on it
Old Feb 2, 2004 | 10:04 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Whatcha need?
The 749 can be found in Sunbird Turbo, Typhoons, Syclones, and the odd Qrand Am with a Quad 4.
The code, mask $58, with a few simple changes, works great for a cheap and effective boosted EFI.
Depending on your injector flow rates, a more easily found 730 ECM can be used in place of a 749 ECM. The determining factor is the 730 requires using saturated type injectors. The 749 has an additional injector driver circuit in parallel to the first, which allowed using Peak and Hold TPI injectors with the Sunbird. However in stock config, the ECM can only run 4 P/H injectors. The ECM can be "upgraded" with heavier duty FETs along with changing a couple resistors to allow running 8 P/H injectors.
The code is quite capable of the task, same with the ECM. Plus its OEM grade. And easy to find a spare.
BW
Old Feb 3, 2004 | 12:44 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The Syclones came with turbos, and ran 14 PSI off the show room floor.
As far as fast with a stock ecm, there's a number of Grand Nationals in the 9's, running stock ecms.
It does take a certain level of sophistication for an EFI car to be fun to drive on the street, the older DFIs were rather lacking in that reguard, and the newer ones are quickly catching up to the oems in complexity.
Old Feb 4, 2004 | 10:06 AM
subsonic9's Avatar
Car: 86 IROC
Transmission: WC T5
suturn5 do you have the part #s and instructions for the mod above? I have tried the search, can't find.
toronto formula
Nov 10, 2015 06:17 AM
efiguy
Sep 27, 2015 01:30 PM
-=Z28=-
Sep 24, 2015 10:21 AM
e3pres
Sep 9, 2015 01:51 PM
