L98 using LB9 pcm
Car: check
Engine: check
Transmission: check
Re: L98 using LB9 pcm
Originally posted by 88Z
What would happen if you hooked up an L98 to an LB9's pcm? Also, what if it's an L98 without the coldstart injector and the LB9 was set up for one?
In '89 the cold start injector went away and was replaced with new software that did the cold fuel compensation with the existing injectors.
RBob.
