Problem reading Error Codes
Old Apr 28, 2004 | 02:20 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Some previous owner removed the EGR, catalytic converter and air conditioning stuff from my car, an 82 Firebird with a 2.8L engine. The bulb was also removed from the SES light. I reinstalled the bulb and it stays on constantly. I went to check the error code from my ECM last night. I shorted out pins A and B on the ALDL connector but the light just stayed on, there was no flashing. I have been doing a complete restoration of the car over the past year and a half and haven't done much milage on it. The car starts and idles fine. I took it out for two 30 mile runs in the last two weeks and it ran fine. I don't know why the SES light stays on. Is there some way to reset it? If there was a problem with the ECM surely the car won't run properly?
Any help appreciated,
Old Apr 28, 2004 | 05:30 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The GM EFIs will drive fairly well in limp home mode.
You need to start at square one, and figure out what's wrong.
Old Apr 29, 2004 | 04:29 AM
gholian's Avatar
Engine: 2.8 V6
Yes, to figure out what's wrong is what I want to do. My car uses a 2 Barrel carb. Is there electrical diagrams on this site for the ECM. I looked in the technical data section but didn't see anything close. When I shorted out pins A and B basically nothing happens (The SES light just stays on). On my ALDL connector there are connections to A,B,C,D and F. The rest are blank. On B I am reading 1.23V should I be reading 5V?
If anyone could help me out I would appreciate it as I haven't a clue about this thing,
Thanks.
File Type: bmp
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bert87
Aug 23, 2015 03:50 PM
mdtoren
Aug 23, 2015 12:52 PM
GouldyGTR
Aug 21, 2015 10:43 PM
