91 ecm question for engine swap
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
hey,im swapping in a 355 carbed engine into my 91 camaro that has a 305 tbi...i was told i wont need my ecm any more but how will all my guages and stuff work if i dont have my computer any more if i have a carbed engine swapped in... can i just cut all the wires that go to the engine and leave the rest? thanx
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
dont take it out your speedo requires it as well as the tach.....i made the same mistake same swap and had to buy a new one..
thx
thx
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
so what do i do? lol... stilll un clear about what happens with the ecm when swapping in a carbed motor
Car: check
Engine: check
Transmission: check
If you remove the ECM harness in one piece you can always sell it and the ECM.
RBob.
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
so even tho i have a 91 with non mechanical guages i will not have a problem with completely removing the ecm? sorry but i just wanna make this clear before i go ahdead and make a major mistake.... thanx alot
Car: An Ol Buick
Engine: Vsick
Re: 91 ecm question for engine swap
RBob is 110 % correct, ditch that ECM. I did it myself and everything works. I used mechanical aftermarket gauges for oil and water, but speedo, fuel, & voltmeter still work fine. If you want to use your factory oil and water just leave the wires and sending units in place. there is no need for the ECM in these vehicles other than operating the fuel injection. but do handle that TCC as Grumpy stated.
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
what will i need for the torque converter clutch to be controlled? should i get a new torque converter? since im going to a 300 hp+ engine?
theshackle
Mar 5, 2017 06:37 PM
