injector settings
Old Jun 28, 2004 | 05:51 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
injector settings
I am having a chip reprogrammed but I need to know what to make the settings for my injectors. I am putting the tune port setup on my stock LO3 305. I have ls1 injectors that flow 28.5 lb/hr @ 58.5 psi. I also have an adj. regulator so I can turn them down pretty far. my big question is what flow rate do I put in the computer? the programmer said he was going to put them in as 19 lb/hr so it thinks it is controlling a smaller injector. is this correct? input please.
Old Jun 29, 2004 | 04:16 AM
contactpatch's Avatar
Engine: sbc 350
What max fuel flow /// whay max horsepower, are
you planning for?
Old Jun 29, 2004 | 04:10 PM
1992rs/ss's Avatar
basically just need it good enough to make engine drive well, not to rich, not to lean.
Old Jun 30, 2004 | 03:33 AM
Engine: sbc 350
If you want that FI to flow at 19 lb / hr,
you'll have to turn the fuel pressure down,
I calculate to 26 psi.
Old Jun 30, 2004 | 06:46 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
I wouldn't turn the pressure down that far, you may get poor atomization, and you might get some funky reactions from the ECM when it tries to change the PW and gets a lot more change than it was expecting. Calculate the flow rate at 40-ish psi and set the injector constant for that.
IMHO a good tuner wouldn't suggest using 28lb injectors and telling the ECM they're 19. It's just a shortcut to get more fuel, when the right way is right there in front of him (just takes a little more time.) Just my $.02.
Old Jul 8, 2004 | 08:55 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm accually running the same injectors and they said it was suppose to be set at 25# in the chip for a 43.5 PSI, but when installed in the LPE 219, 383, SR I was getting 108 BLM across the board. I have since changed the constant to 28 and its all within spec except at idle. Also passed e check with flying colors and also gets 20+ MPG. Drivability is perfect also.
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Firechicken86
Aug 12, 2015 10:07 PM
