Code 43
Old Aug 29, 2004 | 03:26 PM
albertschmitz's Avatar
Car: 88 Roc
Code 43
I replaced the IAC and set the low idle to 500 rpm, reset the TPS. I am still getting a code 43. When under load I get a slight ping/knocking sound. The check engine light comes on after a WOT run wen I lift. During the WOT run the engine seems to free up (i do not know another way to put it) and then the light comes on.
Runs great and idles perfectly now, but I would like to fix this issue with the car.
Car is a 88 IROC F 305 tpi.
Old Aug 29, 2004 | 03:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
After adjusting your idle, you might also need to adjust your timing again.
Old Aug 29, 2004 | 05:15 PM
Car: 88 Roc
Doh, I always forget the easiest things.
Thanks Trickster that was the ticket.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
