park/neutral ecu wire...
Old Sep 7, 2004 | 07:57 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Stock my 87 GTA had 1 orange wire going to ECU that had a park neutral signal>>> what did this do??? If I leave it disconnected will it cause any problems???
Old Sep 7, 2004 | 10:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: park/neutral ecu wire...
It let the ECM know when the trans was placed into drive. The ECM could then compensate for the additional load.
The signal was grounded for in park/neutral, open for drive. Stick cars just left the wire open.
RBob.
Old Sep 7, 2004 | 12:30 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Re: park/neutral ecu wire...
RBob.
yup.
so if you have a auto car that you converted to a manual, and you keep stalling as you're coming to a stop, you just disconnect that wire from ground, and it always thinks you're in gear.
then you can drive it without a new chip..
Old May 19, 2007 | 09:08 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
I hate to open a old thread but I wanted to be sure on this:
The ecm needs a negative signal when the car is in park or neutral? As long as it sees a "ground" in park or neutral and nothing in drive or reverse it'll work fine?
Thanks!
Old May 20, 2007 | 09:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Thanks!
Yes, just leave the wire open, not connected to anything, for 'drive'. With an automatic that wire is grounded when the shifter is in park or Neutral.
RBob.
gixxer92
Apr 12, 2022 12:09 AM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
gta892000
Sep 16, 2015 12:40 AM
