Blue Streak Electronics of Canada
Old Oct 26, 2004 | 11:12 PM
88tatpi's Avatar
Car: Z28HO/TA/Alfa Romeo
Engine: 305-350-502
Transmission: 700R4-5speed
Just when I'm ready to have a look inside the ecm of my '89 TA,
I discover the box has the lable "Blue Streak Electronics of Canada #EM7165" or something similar.
Has anyone out there ever dealt with these boxes?
How do they rate with the standard Delco units?
Thanks!
Old Oct 28, 2004 | 06:19 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
It's just a rebuilt one.
Nothing fancy.
You need to sort of watch what you get thou, if you open it up, and see a bunch of wires hanging off the PCB, be sure to use it as a door stop. There aren't many left, like that, but for a while there were some nastily repaired ecms.
Old Oct 28, 2004 | 01:31 PM
88tatpi's Avatar
Engine: 305-350-502
Well, I took a look under the lid and inside the box.
It's a VERY clean PC card, all the masking, components and soldering is very top notch worksmanship.VERY IMPRESSIVE.
Looks a heck of a lot better than my '88 Z28's computer box.
Maybe it's a Blue Streak box built on a Friday.
Thanks for the "heads up" !!!
Old Nov 3, 2004 | 10:54 PM
muffz28's Avatar
Car: 1992 Camaro Z28
Don't worry about the blue streak name. Blue Streak is a devision of Standard Motor Products. And their ECU's are all farmed out to a company by the name of A1 Cardone out of Phila. Pa, the quality is there. Cardone is a QS 9000 company which is a cert. that is given to a company with very high quality control standards.
Old Dec 2, 2004 | 12:21 AM
BrandenCali's Avatar
I just pulled a 7730 out of a Gt That is a replacement unit the Blue streak.. All I need to do is swap the chip and it seems like it will be a good ecm.. I just need it to work well enough to smog and swap in the gen6 when done..
My stock ecm 165 is a Delphi replacement from the dealer.. Same thing as ac delco there name is right on it.. So ecms They go bad when they go bad that's it..
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Lbibb
May 5, 2016 12:00 AM
gord327
Oct 3, 2015 01:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
