Setting injector constant on C950...
Old Nov 29, 2004 | 07:10 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I know, stupid question, but I was looking through the manual that comes w/ it and I don't see where it talks about it. Thanks.
Old Dec 7, 2004 | 06:28 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
You gotta be kidding me? No one knows how to set the constant for what inj. they're running?
Old Dec 7, 2004 | 10:03 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
It's been a little over a year since I had a C950, but at least at that time they didn't use an injector constant. It was all controlled thru the numbers/counts you put into the fuel map.
Old Dec 7, 2004 | 10:33 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Yep, Vern is right on. There is no setting for "injector constant". Changing the numbers in the main fuel map adjusts for different injector sizes. If you're tuned for a certain injector size and you change injectors, you need to retune your map for the new injectors. I guess as a ballpark for going from 30lb to 24lb injectors you can increase the whole map by 20%, so to go from 24lb to 30lb I would guess that the opposite is true (decrease by 20%) but that's just a ballpark, you still really have to re-tune the map for different size injectors.
-Paul
jklein337
Sep 19, 2018 06:23 PM
bamaboy0323
Sep 3, 2015 06:07 AM
lakeffect2
Aug 23, 2015 08:44 AM
Firechicken86
Aug 12, 2015 10:07 PM
