code 54 help needed
Old Jan 21, 2005 | 04:48 PM
turboclone's Avatar
Car: 86 t/a
Engine: 383 turbo world heads ect.
Transmission: t400
code 54 help needed
getting a code 54 my fuel gauge no longer works. would be gauge no longer working set this code? or is it something else setting this code off? i just bought a whole new sending unit assy.. my exhaust is about 4 months old (came on the car when i got it) i'm thinking if i have to dismantle it to take the tank out to put in the sender i minus well do 2 things while at it. 1 get a hp fuel pump as i'm planning on future upgrades and 2 get a good cat back exhaust seing i have to pull it half of it down anyway. so if it's just the sending unit causing the 54 i can live with it for a few.
Old Jan 21, 2005 | 06:06 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Code 54 on the '86 MAF f-body's is a fuel pump relay failure. This just means that the relay that drives the fuel pump is not providing the proper voltage. The relay is probably failing.
RBob.
Old Jan 21, 2005 | 08:02 PM
turboclone's Avatar
Car: 86 t/a
Transmission: t400
strange as it is, i have had a constant service engine light. the car has been hard starting also. anyway, i pulled the codes and now no service engine light and get this, it's starting great. guess the relay is a good call. probably on the fritz. i'm going to replace it, chances are next time i won't get lucky and have a lazy one, next time it won't work at all thanks for your input. i just got the car last week. it had a rough idle so i gave it a compl. tune. took the dist. cap off and the rotor FELL OFF! must have had the luck of the irish . drove the car for about 15 miles and parked it in my garage. one more mile/minute and it would have died! the fuel gauge doesn't work and a complete sending unit came with it but i'm going to check it out. might not even be a faulty relay. thanks
lee01
Apr 9, 2016 01:56 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
