Tpi ?
Car: 1983 G20 Chevy
Transmission: 4L60
Tpi ?
I am looking for a little info before I start my TPI swap and tuning project. I have the engine in my signature and am about to swap to a mass air TPI out of an 89 camaro 350. My question is do you think that the engine will be driveable with the stock chip until I can address the issues.
Also which is the best BIN to start with?
Car: 1989 Trans-Am
Engine: 454-Motown SBC w/HSR
Transmission: 6-Speed
Re: Tpi ?
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
No flame intended but it seems to me it would run better if you told the computer the engine was a 454. I'm sure it would be interested in knowing. It would be driveable but give it a better fuel and timing curve than a factory L98. As Grumpy has said many times give the engine what it wants and you will see more power. The L98 chip is at best a compromise. As you may know an L98 benefits from reprogramming, mine sure has and I'm not done yet.
Car: 1989 Trans-Am
Understand though, this particular swap was kind of hard on the bank account. With what I just recently spent on the car, and according to the wife... it'll be running as-is for awhile (at least until Spring).
Future mods call for a HSR, along with the proper tuning of course.... but until then, I have no choice but to run the stock ECM.
Again though, she idles suprisingly well. However, she does fall flat on her face anywhere above 4000-RPM, all thanks to a stock TPI unit.
Car: 1989 Trans-Am
Originally posted by TPIJeep
Damn... my 454 wouldn't run worth a crap using the ECM file from my 415 with the same size injectors..
Car: 1983 G20 Chevy
Transmission: 4L60
Glad to hear that. Means I can turn the fuel pressure up a little and hopefully not have to worry about not being able to drive it until I tweak it enough.
Sanjay
Aug 12, 2015 03:41 PM
