replacement ecm connectors
Car: 89 iroc convertible
Engine: 305 tpi
I have searched for several hours and only managed to find one thread that told someone else that there was a thread on replacement connectors and to just do search. I had no luck. Anyone know or have any idea who readily sells replacement connectors (just the plastic part)????
im using a 747 ecm
im using a 747 ecm
Car: check
Engine: check
Transmission: check
Not sure which connectors, the harness side or the ECM side you are referring to. I don't believe the ECM side connectors are available. No one that I know of has found a source for them, short of removing them from a trashed ECM.
The harness side connectors are available from GM. Better place is a junkyard. Also try powerandsignal.com
RBob.
RBob.
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Engine: 305 tpi
gta that site doesnt work? Anyway guys I found a source. It took alot of research. I ended up finding them in my back yard almost. It is a place in Marine City Michigan called Howell engine development. They are super easy to deal with. I spoke with Troy and he helped me out.
