tuner pro seems to be a useless program
Old Mar 15, 2005 | 04:58 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
ok, so I wired up my aldl port to work with my new tpi setup. I go to connect with the ecm with the key turned forward to on and it won't connect. I supposedly have the right file to read the 730 ecm and before I switched I had to set it to com 4 with winaldl and I would get readings. now with tunerpro I get nothing!!!! I am really starting to hate this program. the only thing I have not tried is trying to connect with the engine running. my dist. is not in right so it doesn't want to run at this moment. all I want to do is make sure that when I get it running I can read my sensor data. I am thinking of finding a diff program cause this just doesn't seem to work. if you have any ideas please help me out here.
Old Mar 16, 2005 | 11:50 AM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
Are you sure you have tuner pro set for the correct port # in the preferences settings. Also make sure you have the ADS file setup in the aldl setup page.Maybe test your cable on a friends running car to make sure your cable actually works. Im using tuner pro to datalog with an autoprom so i know it not a completely worthless program.
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
85Special
Sep 3, 2015 04:21 PM
