Where does the blue wire for TPS hook up to ECM?
Old Jun 11, 2005 | 09:59 AM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
Please help i keeep pulling a code 21 and the voltage reads correct on the TPS but every once in a while the code pops back up again and i think it may be a loose and bad connection.
Old Jun 11, 2005 | 11:33 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The blue is on C13 of the ECM. This is the middle wire on the TPS and is the signal to the ECM.
Gray is the +5V ref from pin C14, and black being the ground (looks like D2 on the ECM).
This information is only correct for the MAF setup of the '88 in your sig.
RBob.
Old Jun 11, 2005 | 11:51 AM
trueburton's Avatar
Yes that is the correct car in my sig. Where is the c13 pin at? is that on the wire harness connecting to the ECM?
Old Jun 11, 2005 | 02:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is the pin number of the ECM connector. One connector is pins A & B, the other C & D, then the numbers.
These letters/numbers are molded into the harness connector where the wire enters and also inside of the ECM connector. Pull the plug out and those letters/numbers can then be seen.
RBob.
Old Jun 11, 2005 | 03:02 PM
trueburton's Avatar
yeah i pulled the ecm out and found them thanks. Woiuld it be a good idea to spray those connectors with cleaner and then apply some dialectric grease to the connectors?
specialized
Jun 18, 2022 09:26 AM
bamaboy0323
Sep 3, 2015 06:07 AM
djmarch
Aug 19, 2015 12:07 PM
stalkier
Aug 7, 2015 04:49 AM
