Is this my stock MEMCAL?
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
Iv got a code 41 and its related to the PROM ive been told, so i checked to see if it had been tampered with. the pictures in the sticky post show and say the cover should be blue, and mine is a white hypertech cover. Iv posted the best pics i can get of it. Also, what is that small chit under the bigger one?
Im guessing this is not original, and if not, is it good or bad if i want to get into programming my own PROMs? If it is not original will i be able to treat it as if it was when i go to un-soilder and switch PROMS?
thanks for any help with it.
Car: check
Engine: check
Transmission: check
Surely not the stock MEMCAL. I can see why it gives a cylinder select error (41). I can't even fathom why there is a little chip under the EPROM. Best bet would be to get the latest MEMCAL from GM (or used).
RBob.
RBob.
Engine: 305ci TPI
Thanks for answering, i didnt think it was stock. im assuming its not very good since it could not of been specific to my car, but a general program for many cars like mine which could all be running different.
anyway, since i want to get into my own programing of PROMs, would it be best to get a stock MEMCAL for my car and go from there as if this one was never there? Could work off of this one?
Engine: 305ci TPI
actually, how would i go about getting a stock MEMCAL? would a GM dealer be able to get me one? i think i would need the whole MEMCAL and not just the PROM because this MEMCAL doesnt have the NetRes that iv read about
Engine: 305ci TPI
iv tried to take care of it myself, but its to the point where iv got to ask if anyone else can help. a GM parts guy and i looked throught thier computers to find a memcal for it, and there is no exact match. would anyone know a part number or help me to find a part number for the memcal??
car is an '86 IROC, LB9, (F) engine code, auto 4spd tranny, federal emissions, A/C...
thier computers ask and display all this kind of info, sometimes even rear end ratios. it seems they cannot get me a perfect match, so should i get a memcal for an 86 LB9 F with auto and ignore the others like A/C and emissions?
possibly lead me to a place to find a part number?
THANKS for any help with it!!
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
that is an aftermarket generic chip. hypertech was one of the first companies to enen attept tuning efi. i believe the smaller chip is the esc module but not sure. what year is the ecm?
Search Keys:
Model Year: 1986
Platform Code: FB
Engine RPO: LB9
Transmission Type: AUTO
Emissions RPO: +NA5,+NB2
BCC,Year,Rel Date,EPROM #,ECM #,PROM ID,SCAN ID,Platform,Eng,Disp,Trans, , ,Trans Type,Gear Ratio, , , , ,Emissions, , ,Emis Cat,GVWR
ANY ,1986,09/17/86,01228290,01227165,3234,9501,FB,LB9,5.0, , , ,AUTO, , , , , ,NA5,NB2, ,* ,C60, ,
AUM ,1986,09/17/86,01228291,01227165,3236,9521,FB,LB9,5.0, , , ,AUTO, , , , , ,NA5,NB2, ,* ,C60, ,
BTZ ,1986,09/17/86,01228292,01227165,3240,9511,FB,LB9,5.0, , , ,AUTO, , , , , ,NA5,NB2, ,* ,C60, ,
AWC ,1986,09/17/86,01228293,01227165,3243,9531,FB,LB9,5.0, , , ,AUTO, , , , , ,NA5,NB2, ,* ,C60, ,
ANY ,1986,07/18/85,16058977,01227165,8980,9501,FB,LB9,5.0, , , ,AUTO,GU2, , , , ,NA5,NB2, ,* ,C60, ,
BTZ ,1986,07/18/85,16058984,01227165,8987,9511,FB,LB9,5.0, , , ,AUTO,GU2, , , , ,NA5,NB2, ,* ,C60, ,
AWD ,1986,07/18/85,16059000,01227165,9004,9541,FB,LB9,5.0, , , ,AUTO,GU6, , , , ,NA5,NB2, ,* ,C60, ,
AWF ,1986,07/18/85,16059006,01227165,9009,9551,FB,LB9,5.0, , , ,AUTO,GU6, , , , ,NA5,NB2, ,* ,C60, ,
Engine: 305ci TPI
That is really good info, thanks for that. GMpartsdirect could ony find the 2nd to last one, with AWD BCC code. It doesnt give a clear description of what it is on that site though. It says it is "CATEGORY: Emission Control System Hardware". I want to be very sure it is what i would need before i buy something, at a dealer they had tyhe order way wrong.
I was wondering, where were you able to find that chart info? It is the right car and all i was just wondering.
And one more, is there only one memcal part number that is the real one for my car? Are u saying that these will work even if not perfectly made for my car? It looks that way but i dont know different BCC or ID will do.
i really appreciate info or help with this, im just starting out with the computer aspect of cars.
The info came from CalData, a database of eprom info you can buy from TunerCat.
They all suit your car, they are just revisions that were released over time. This is why its most likely that your dealer only stocks the more recent version.
Engine: 305ci TPI
Cool, thank you, i tried the demo of caldata but it only worked for 1990 cars i think. Ill have to head down to the GM dealer and see what they can get me with those numbers. hopefully it will all be good and well but if not ill just have to find another source.
thanks again
thanks again
Genopsyde
Oct 7, 2015 08:35 PM
