VSS signal intercept
Old Nov 8, 2005 | 09:52 PM
lostreception's Avatar
Car: 90 Chevy G20
Engine: 350 TBI 5.7L LO5 1227747
Transmission: 700R4 3.42
From what i understand the transmission will send out the VSS signal by either a cable or an electronic module
this then is interpreted by the ECM and will then be sent to the speedometer....
Background
350 TBI 5.7L 7747 engine
is there a way to intercept (parallel) the VSS pulses and process it thru a serial cable and display speed /odometer reading thru a laptop
i have a car pc and would love to be able to log my miles digitally. does a program or a possibility of one exist?
Old Nov 9, 2005 | 06:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Most likely something will work. Someplace along the line the VSS pulses become digital. It is the digital signal that is fed to the ECM. 350 TBI w/7747, I'd say the VSS is an optical unit in the dash. A lime green colored box converts the signal to digital where it is fed to the ECM. At this point it is a 0 to 12 volt signal.
Two ways to get it into the laptop: serial port or parallel port. Then have a simple program on the laptop monitor that input and count the pulses: 2000 pulses per mile traveled. The serial port may reconize the +12 v signal on an input such as DTR (or CTS, DSR, which ever is an input).
A voltage divider and input the parallel port can also be done.
RBob.
Old Nov 9, 2005 | 12:08 PM
Car: 90 Chevy G20
the other thing i thought about doing was tapping into the feed going directly to the speedometer needle in the dash. is that read on resistance or voltage. if its a linear signal 0MPH=0v and 140MPH=12v the conversiong should be like eating pie anyone know what the ecm sends to the speedo needle
Old Nov 10, 2005 | 12:40 PM
Car: 90 Chevy G20
forgive my ignorance in the earlier post i now know that the vss buffer sends out the signal to the gagues
my only remaining question is how is it ran (signal wise)
tranny > buffer> ecm > gague
analog - analog - digital - digital
ohms? - ohms? - volts? - volts?
Rbob your the ECM mastermind what is the ecm getting to create the values for speed (7747 of course)
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
thunder57
Nov 7, 2015 02:28 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lewandom
Oct 1, 2015 08:15 AM
