Need some info on code retreival
Old Nov 18, 2005 | 08:02 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Ok i may get shot for this but here goes...
I know that if you jump terminals A-B on the connector thingamajig you can get any codes their are, is this the same on all GM models?
My sisters piece of junk 93 Geo has some issues but i dont need to cook the computer in it
Old Nov 19, 2005 | 08:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If it has the standard 12 pin ALDL connector, then I'd say yes.
RBob.
Old Nov 19, 2005 | 12:04 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Alright, im blaming it on you it it caches fire
Old Nov 21, 2005 | 10:17 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Well it turned out alot easier than i thought.
While replacing the half dozen blown fuses i found one empty slot that was labeled diagnostic. so i plugged a fuse in there, turned the key and she gave me a code 13!
Only $40 for the new O2 sensor, popped it in and shes happily on her way again.
BumpaD82
Feb 26, 2016 02:57 PM
Shane87irocz
Sep 22, 2015 06:21 PM
lethaldomestics
Sep 21, 2015 01:18 PM
Reese-J
Sep 14, 2015 02:43 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
