MAF table 1-6 Scalar 6E bin
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
I did a seach didn't really help much. Heres my question MAF table 1-6 Scalar ( ECM 6e bin), increasing the values will increase my fuel % right? Reason i'm asking is because, I see MAF table #1-6 and MAF table #1-6 Scalar in tunerpro. Which one is it or is it both?
Car: check
Engine: check
Transmission: check
Increasing the value in the MAF tables will increase the fuel. See the Tuning Book sticky on the PROM board. Under MAF, $32, $6E there are several good articles on how the MAF tables work.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Originally posted by 8UpAFord
crap so MAF table 1-6 Scalar doesn't help increase fuel. I'll check out that sticky.
Prom Tuning Guide Book and FAQ: Common Questions and Answers
https://www.thirdgen.org/techbb2/sho...hreadid=288763
Then under 165:
MAF Miscellanea
MAF Scalar Tables
Nite: skip/ignore the $32 tuning information, it has nothing to do with the MAF scalar tables.
RBob.
Car: 1988 Corvette
Wow not fun. I'm running lean at Idle and little rich arond 3000rpm. Plus i removed my MAF screens in the past Its problay a bad idea. I'm guessing maybe just bump it up a few noches in the scalar tables then increase by like 10% in the MAF tables then datalog it.
Trying to understand that math is giving me a headache
Car: 1988 Corvette
I'm also adcvancing timing in my low rpms and retarding in the upper casuing this lean/rich mixture. This MAF table stuff is burnin me out. There is the MAF tables 1-6 then the MAF scalar 1-6 then the MAF vs. RPM. Can you shed some light on this please. I've read all the stickys on it, is there a good amount i should increase with my MAF mods removing the screen. IF i can get a hint or too I'll be very happy. Sorry man maybe i need to take a break and read it again later tonight or something. but anything to help would be great
Thank you
Thank you
