The Prom Tuning Guide Book and FAQ: Common Questions and Answers
Old Apr 3, 2005 | 03:29 PM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
This is currently under construction and will help to organize and sort the stickies out and to minimize clutter due to growing information and topics.
As you may have noticed the stickies have been getting dropped. The Chapters that are linked will also be replaced and be non hyper text due to the stickies not being updated and are lacking all the latest links that the actual "Guide" has. Thanks for sending/recommending posts and links. Where appropriate they have been included.
later and thanks
The mod squad :-)
CHAPTER 1: WHERE DO I BEGIN? HOW TO PROGRAM PROMS.
CHAPTER 2: SOFTWARE: WHAT YOU NEED TO MODIFY YOUR BIN, DEFINITION FILES AND SOURCE CODE
CHAPTER 3: HARDWARE: ADAPTERS, TEST BENCH, DRIVER BOARDS, EMULATORS
CHAPTER 4: MAF vs. MAP: CONVERSIONS AND DEBATE
CHAPTER 5: TUNING ARTICLES BROKEN DOWN BY ECM
7730:
6870/7302:
165:
749 ($58):
749/730 ($60)
8063/7747/8746 ($4D/$42/$61):
CCC(Computer Controlled Carb)
3.8TransAM's Avatar
CHAPTER 6: SOURCE CODE: MODIFYING, PATCHING AND TESTING
CHAPTER 8: GRUMPY'S FINAL ANSWERS AND IMPORTANT TOPICS
CHAPTER 9: LAPTOP TO ECM COMMUNICATION AND OPTIONS
For this, let's not take into account what hardware you specifically may already have, but what hardware is available for the different configurations. This allows us to be more general, which is useful for the masses.
Note: This pertains to being able to emulate and datalog at the same time. The outline below is not necessary if you only wish to emulate or datalog independently. This assumes real-time emulation is what is desired.
Note 2: This reply does not take into account all emulation/ALDL hardware. Use the info that is here and the info you have for the hardware of your choice to determine port and configuration compatibility.
The following suggestions should work well with most ALDL and Tuning software, namely:
Tuning:
TunerCat
TunerPro
Datalogging:
Datamaster
TunerPro
WinALDL
EASE
FreeScan
etc
PC Configuration 1: 1 Serial port, at least 1 PCMCIA slot, no USB ports (this is probably the most common)
One of the better routes to go would be to go with a PCMCIA USB hub. I believe Craig sells one for $20 (the guy sells everything, doesn't he?).
With this, you have a couple of hardware options:
Tuning Hardware Option 1) (Recommended for compatibility simplicity)
- Serial ALDL cable
- PCMCIA USB hub/interface (Moates sells one for $20 - of course - he sells everything, right?)
- Ostrich (USB emulator)
With this setup, you can get up and running with minimal effort.
Tuning Hardware Option 2) (Still recommended, but a little harder to configure)
- Serial ALDL cable
- PCMCIA USB Hub/interface
- Serial to USB converter
- Romulator
This setup is a little harder to configure and may not work in all situations (because of the involvement of a serial to USB converter), but will probably work in 9 out of 10 PC configurations. The idea is to use the serial to USB converter with the Romulator, since it uses a very standard 115kbaud communication baud, which is compatible with all converters. Doing it this way is recommended over using the USB converter for the ALDL cable since 8192 baud is not universally supported by USB converters.
PC Configuration 2: 1 Serial Port, 1 or more USB ports
- Serial ALDL cable
- Serial ALDL cable
- Romulator
Again, a little harder to configure because of the use of the serial to USB converter, but it should work great under most circumstances and with most software.
PC Configuration 3: 1 USB port, 1 or more PCMCIA slots, no serial port
- USB ALDL Cable (from Moates)
- USB ALDL Cable
- Romulator
PC Configuration 4: 2 USB ports no serial port
- USB ALDL Cables (from Moates)
By far the simplest setup
- USB ALDL Cable
- Romulator
(Courtesy of Mangus, author of TunerPro)
Old Apr 20, 2005 | 01:35 AM
3.8TransAM's Avatar
CHAPTER 10: PROM ID FOR APPLICATIONS(YRS AND MODELS)
CHAPTER 11: MISC. ISSUES
CHAPTER 12: KNOWN ECM HACs
This is a collaborative effort of Bob, Glenn and Jeremy. The basis for this guide came from Tim's original sticky collection (posts and links collected from this board) and has been modified in format and text and updated where appropriate. So much new material has come forth and new topics written that we would again reclutter the board with a mass of stickies. This project has been undertaken to hopefully map out the "prom tuning bible" if you will and organize the information here at thirdgen.org to the best of our abilities.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
ezobens
DIY PROM
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
DIY PROM
Aug 11, 2015 10:22 AM
