730 almost = 749?
Old Dec 30, 2003 | 01:32 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
730 almost = 749?
ok, now im confused........ im being told that with the exception of the injector driver, the 730 and 749 is the exact same ECM..
i want to run $58 for my car since im going to be putting a supercharger on it.... can i just put the chip i was making for the 749 in the 730 and not repin my car (only a few pins but still)??
any downsides? its like people mention it, but noone goes into detail about using the 730 like a 749.....
Old Dec 30, 2003 | 02:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 730 almost = 749?
They are not the same. They have the same PCB board but are stuffed differently. So it all depends upon what you want to do with the ECM.
If you have a '730 and want to run the $58 code in it you still need to re-pin the harness. The $58 code uses different output pins then the $8D code (TPI '730 code). This part is good for you.
The '749 is short a quad driver, so you will lose the TCC lockup function if running $8D code in it. IIRC there is another driver in one or the other but can't remember which. It is a single output driver.
RBob.
Old Dec 30, 2003 | 08:53 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well you have to repin because they are mostly (90%) the same.
But as long as you can run the same code base, and swap ECM's in and out that most of the drivers are the same. This seems to be true for $58 code.
Ahh. He asked this question in another thread, but said it wrong. He said there was no TCC in '730 if you run $58 - which is incorrect.
F6 on '749 is a dead pin ?
I'm running a manual, so I wouldn't have noticed.
-- Joe
Old Dec 30, 2003 | 08:56 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You can run $58 in the '730 for your application, of a TPI setup. You won't be able to run low imp injectors, but you won't need to on your car anyway.
-- Joe
Old Dec 30, 2003 | 10:32 PM
18436572's Avatar
Car: 69 Camaro
Engine: 355 SBC
Transmission: Glide
Axle/Gears: 4.88 full spool
I asked a stupid question and then found the answer on my own. I tried to delete it and It did not work so let me say this,
Have A Great Day!!
Old Apr 12, 2008 | 07:49 PM
???'s Avatar
just to clearify...
you have to repin your 730 is if its a 749 like in this post..
https://www.thirdgen.org/1990conversion
and then load .xdf file,.ads and .bin files for the 749 onto your 730 chip?
Old Apr 12, 2008 | 09:13 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally Posted by ???
just to clearify...
I used to think so. If you don't repin it should work fine.
-- Joe
Old Apr 14, 2008 | 03:23 PM
???'s Avatar
well just to follow up...
i didn't change any pins, just dumped a starter bin from the code59 site, changed it to 8cyl and it fired right up and idled.
its rich but worked, i am going to add the WB wires and the shift light one but still. works well.
junkcltr
DIY PROM
26
Jan 22, 2022 10:53 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
355tpipickup
Aug 19, 2015 10:02 PM
SATURN5
DIY PROM
Jan 25, 2001 12:07 AM
