baro/da calculations (730 8D)
Old Aug 24, 2004 | 09:58 AM
11sORbust's Avatar
Is there any, how does it work? From what I understand, the ecm checks barometric pressure when the key is forward, just before the engine starts and the map sensor is used for this. At the same time, the ecm checks the ambient temps vie MAT. Then it'll offset the PW, I guess.
Old Aug 24, 2004 | 11:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: baro/da calculations (730 8D)
There really isn't a need for a DA calculation. The PW is calculated from the VE, MAP, MAT, EGR partial pressure, cylinder displacement, and injector flow terms.
As you mentioned the baro is read at key on via the MAP sensor. There are also pseudo baro reads done while the vehicle is being driven. This allows baro to be updated during those Pikes Peak climbs
Barometric pressure is used to modify the VE term. Notice that the table at $881F increases the VE as the barometric pressure drops.
RBob.
Old Aug 24, 2004 | 03:21 PM
11sORbust's Avatar
; VE Mult vs BARO
; TBL = MULT * 128
; MULT Kpa BARO
L881F: FCB 152 ; 1.188 65
FCB 146 ; 1.141 75
FCB 139 ; 1.086 85
FCB 133 ; 1.039 95
FCB 128 ; 1.000 105
How much does the table effect fueling? More than the MAT tables? Could you explain how the calculation works? I think this stuff is starting to sink in..
Old Aug 24, 2004 | 03:30 PM
11sORbust's Avatar
How does that work.
Old Aug 24, 2004 | 03:38 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Lets say the VE is 78% and baro is 105 KPa (see above post, table is quoted). The calc is:
(78% * 128) / 128 = 78% VE
So no change in VE%
After a hill climb the baro is 85 KPa, the calc is:
(78% * 138) / 128 = 84% VE
RBob.
Old Aug 24, 2004 | 03:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
How does that work.
As the vehicle climbs Pikes Peak the elevation increases. The barometric pressure decreases with an increase in elevation. . .
And here I thought you'd be asking about why the VE is increased with a decrease in barometric pressure. . .
That first answer wasn't the one you were looking for, was it? A pseudo baro read is done at low RPM, high TPS, with some adjustments the MAP reflects baro and is used for a new barometric term.
RBob.
{edit: spellling, spellinh, spelling. . .}
Old Aug 24, 2004 | 04:17 PM
11sORbust's Avatar
Is there something in the code ?
Old Aug 24, 2004 | 05:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Umm, yea. Unless I don't understand the question. The ECM doing a pseudo baro read does need to have it coded up.
RBob.
Old Aug 24, 2004 | 07:59 PM
11sORbust's Avatar
Sorry, I didn't make the question clear. The table at $881F is applied when the key is forward w/ engine off, right? I don't understand how the ecm can sense the change in baro while the engine is running.
Old Aug 24, 2004 | 09:06 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The table at $881F is in effect whenever the engine is running.
RBob.
Old Aug 24, 2004 | 10:25 PM
JP84Z430HP's Avatar
Car: 84 Z28
Axle/Gears: 9-bolt, 3.27
This is interesting, even though I don't do much driving that would cause a change in BARO.
Old Aug 25, 2004 | 08:46 AM
11sORbust's Avatar
Thanks for the help
Old Aug 26, 2004 | 09:48 PM
Section162's Avatar
Car: '90 Formula
Engine: L98 --> Ramjet
Could you explain why this is? For some reason, sounds backwards to me.
Old Aug 26, 2004 | 10:53 PM
11sORbust's Avatar
less pressure=less altitude + improved performance
Old Aug 26, 2004 | 11:14 PM
JP84Z430HP's Avatar
Car: 84 Z28
I thought BARO was higher with a higher altitude? The air is also less dense at higher altitude, therefore less efficient? So, wouldn't the VE be less at higher altitudes? (That is assuming that VE was reflecting real world differences in volumetric efficiency)
I may be way off here, but I really NEED to understand this. Not because I go to higher altitudes, but just to further my knowledge and understanding of what we're working with.
Old Aug 27, 2004 | 08:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Barometric pressure decreases with an increase in elevation. Standard air at sea level has a barometric pressure of 101.3 KPa. At an elevation of 3,000 meters barometric pressure dops to 70.0 KPa.
At the mile high city of Denver (5280 feet) barometric pressure is ca. 84.0 KPa. At key on the ECM will read the barometric pressure and save it for future use. Someone in Denver with a scan tool will see the reported barometric pressure reading of 84 KPA +-. Plus/minus due to weather conditions. This can be seen as the MAP reading before the engine is started.
This same person will see a maximum MAP reading of 84 KPA even when at WOT. No 100 KPa MAP readings for this engine. As such the VE table along with the rest on the induction calculations are correct. This covers the intake side of things.
However, as previously noted, the lower BARO reading will have the affect of increasing the VE term. Something has happened that increased the volumetric efficiency of the engine system.
There is less backpressure on the exhaust portion of the system.
This increases the VE of the engine.
RBob.
Old Aug 27, 2004 | 09:09 PM
11sORbust's Avatar
That explains a lot. Someone told me the map sensor wouldn't hit 100kpa if there is an air restriction somewhere on the engine. I can't hit 100kpa because of my elevation.
Old Aug 27, 2004 | 10:58 PM
JP84Z430HP's Avatar
Car: 84 Z28
RBob.
Now I get that.
Although, I still don't see the total picture. Not doubting you, just not understanding. Even though there's less backpressure on the exhaust, the air going into the intake is less dense, and under less pressure (without a power-adder) and I would think that would still offset the gains in exhaust flow. If higher altitude made more power, why are sea level corrections higher than high altitude?
Sorry to be so antagonistic, but I'm sure this will help some other people, too.
Old Aug 28, 2004 | 08:06 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by JP84Z430HP
Now I get that.
At a greater elevation the VE will be higher for any given point of MAP & RPM.
Lets take that Denver car and put it on a dyno. Lets say at 5,000 RPM and WOT (84 KPa MAP) it is making 300HP.
Drive to sea level dragging that same dyno along (eliminating all other variables here).
Strapped to the dyno at sea level with the engine throttled to produce 84 KPa of manifold pressure (MAP) that engine will be making less power.
It is less efficient due to higher exhaust back pressure. It will not make the same 300 HP as it did in Denver, it will be less.
According to the VE baro adjustment table GM has provided (see post above) the HP will be down ca 8.5%.
RBob.
Old Aug 28, 2004 | 03:01 PM
JP84Z430HP's Avatar
Car: 84 Z28
RBob.
So at a given KPa of MAP, it will be more efficient? At the lower altitude, it will take a higher KPa to make the same horsepower? Will the peak horsepower be the same (as long as the proper corrections are made for the altitude compensation)?
Old Aug 28, 2004 | 08:36 PM
11sORbust's Avatar
check out this link.
http://wahiduddin.net/calc/calc_hp_dp.htm
Old Nov 8, 2004 | 09:55 PM
11sORbust's Avatar
Rbob, what about these tables. You didn't mention anything about them IIRC, thanks.....
* BARO FORM PARAM'S
L86C3: FCB 96 ; MIN TPS FOR BARO UPDATR, 37.5 %
; ARG = VAL * 2.56
L86C4: FCB 1 ; MAX DIFF MAP FOR BARO UPDATE 0.31 Kpa
; ARG = VAL * (256/80)
L86C5: FCB 144 ; READ BARO THERSH 3600 RPM
; ARG = VAL/25
L86C6: FCB 11 ; MAX BARO OFFSET THRESH, 4 Kpa
; ARGD= VAL * 2.71
; BARO PRESS vs RPM & TPS
; ORG $86C7
; Table = Kpa * 2.71
L86C7: FCB 16 ; RPM min,
FCB 48 ; TPS min
FCB 6 ; Num line in table
; 1200 RPM Kpa TPS
FCB 8 ; 2.952 37.5%
FCB 3 ; 1.107 50.0
FCB 1 ; 0.369 62.5
FCB 0 ; 0 75.0
FCB 0 ; 0 87.5
FCB 0 ; 0 100.0
; 2400 RPM Kpa TPS
FCB 16 ; 5.904 37.5%
FCB 16 ; 5.904 50.0
FCB 8 ; 2.952 62.5
FCB 5 ; 1.845 75.0
FCB 3 ; 1.107 87.5
FCB 1 ; 0.369 100
; 3600 RPM Kpa TPS
FCB 16 ; 5.904 50.0
FCB 16 ; 5.904 62.5
FCB 16 ; 5.904 75.0
FCB 11 ; 4.059 87.5
FCB 5 ; 1.845 100
Old Nov 9, 2004 | 01:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
They are used for the pseudo baro read. Now where did I put that humidity sensor. . .
RBob.
Old Nov 9, 2004 | 08:32 PM
11sORbust's Avatar
Sorry to keep bothering you on this but could you explain exactly how they work?
Old Nov 10, 2004 | 01:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Would basically how they work be close enough? The TPS & MAP need to be in a steady state. The TPS% needs to be above a certain level, while the RPM needs to be below a certain level.
The current RPM & TPS is used to lookup a correction term. This correction is applied to the current MAP value and is used as the new barometric value.
The correction term is based on N-alpha principles.
On modified vehicles I'll first disable the pseudo baro read. Once the tune is in better shape I'll re-enable it and tune in the pseudo baro read. A lot of work here can simply be done from data logs. Engine changes such as heads, cam, TB, intake manifold, will change the pseudo baro read.
RBob.
Old Oct 28, 2005 | 08:05 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Was bored and reading through the stickies.
Thought I might have something to add:
Along with less exhaust pressure (which won't change VE significantly), the angle of the throttle DOES make a difference so long as the pressure ratio (downstream of throttle to upstream of throttle) is ~.5 or higher, meaning 50-100 at 100kPa baro, 40-80 at 80, 30-60 at 60. Less than that, and the sonic flow through the throttle will not change or give a darn what's happening upstream, and only knows what's on the manifold side (meaning the angle of the throttle still controls the flow, but the pressure on the intake side is what determines the flow directly).
At pressure ratios greater than .5, the ambient pressure makes a difference. In order to get the intake to 75 kPa in an ambient of 100 will take 30% throttle on car X. At 80 kPa BARO, it takes 50% throttle = more open throttle = less drag. This small amount makes a difference on VE (that's VE -- not maximum airflow, but airflow vs MAP).
Here's another mind blower: Why does idle MAP get lower at higher BARO? It should still need the same power to overcome accessories right?? Well, I'm thinking it may have something to do with the pressure ratio again, but not the same way - not at the throttle. I'm thinking of the crank case pressure, on the underside of the pistons. Less pressure to push against = higher efficiency. This one just popped into my head while typing, so could be seriously flawed.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Elephantismo
Feb 13, 2019 12:51 AM
PurelyPMD
May 5, 2016 04:57 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
355tpipickup
Aug 19, 2015 10:02 PM
