`7730 Optical VSS Input Pin #?
Subscribe
Jan 27, 2006 | 05:53 PM
Hey guys!
I'm gonna burn a prom for my 7730 ECM that disables a few emmissions systems, VATS, etc, but also switch it from the AC VSS input from the transmission to an optical 2000 ppm input from my speedometer head.
Which pin should be used for the 2000 ppm input pint? Or is it the same as the original VSS Hi input pin?
Reply 0
Jan 27, 2006 | 11:39 PM
You need to send the 2000ppm signal to pin C6. You also need to modify the PROM and change it to non-magnetic VSS.
It is NOT the same as VSS_HI. The optical uses VSS. You are using opitical now right?
Reply 0
Jan 28, 2006 | 12:22 AM
Alright, thanks!
Thats what I needed to know
I know I gotta change the prom, but didn't know which was the new pin to use with it
Reply 0
Subscribe
