TTS Datamaster settings, need linking help
Old Jun 2, 2006 | 09:45 PM
Steve40th's Avatar
I have a 93 Y Body coupe. I am useing TTS Datamaster 3.41. Yes its old but it works. My laptop is a P4, 3.GHZ blah blah Compaq. I have a com port available when I go to record, but it just recently stopped linking up. I use an AKM serial to USB cable. I looked at the help section on TTS and it is kinda vague, especially when there is an intermittent problem.
Can anyone tell me what they have found to work good with the settings in the Options, Advanced -serial communications timing. I used default, then played with the ALDL timing up to 200mS and no link. I even changed chips within the ECM to see if there was something a miss.
Any advice ona smooth link up that you have found to work with 93 ecms or any useing TTS datamster would be appreciated.
Or, is there something I need to disable. I already disabled the infrared and printer ports. ALso, my laptop doesnt use a mouse, and i have installed and uninstalled the drivers many times.
Thanks in advance, Steve
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
