Holy cow I need Help! Vats
Old Jun 6, 2006 | 08:55 PM
gasmonkey's Avatar
Car: 1992 z28
Engine: 5.7 350
Heres the deal. 92 z28 was running great. Started up every time. All the sudden sometimes it will not start and the security light pops up. Usually it flashes then disappears. Ive thought it was the starter before I figured out it was the security. Then I thought maybe the tumbler was wore out. I havent done anything yet because I cant pin point the problem. Did a flash test and got a code 46. That would be the vats. After so long do these vats security systens tend to just malfunction. What can be done to fix this killer problem. Ive seen bypassing and chips. Im running in circles and late to work! thanks
Old Jun 6, 2006 | 09:12 PM
cadman277's Avatar
Car: 95 z28,86 iroc
Engine: 350 lt1,305 tpi
a new ignition cyliner and keys should fix the problem.
Old Jun 6, 2006 | 09:20 PM
gasmonkey's Avatar
Car: 1992 z28
Engine: 5.7 350
I hope thats it! Thanks
Old Jun 6, 2006 | 09:35 PM
gasmonkey's Avatar
Car: 1992 z28
Engine: 5.7 350
I hope thats it! Thanks.........Other suggestions
Old Jun 9, 2006 | 06:27 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
You can purchase an aftermarket chip and specify vats to be deleted. That's what I did. Purchased the chip from TBI CHIPS
They also sell tpi chips..if you're wondering.
Old Jun 9, 2006 | 12:23 PM
markymarco's Avatar
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
my dad and i actually are having the same problem we just purchased a new key and ignition cylinder that should deffinitly fix the problem
Old Jun 9, 2006 | 10:38 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
If the tumbler was wore out, the key probably wouldn't turn in the cylinder. First take some rubbing alcohol and clean the resister pellet real good. Worth a shot before you go and replace the cylinder.
Old Jun 10, 2006 | 11:22 AM
91 Z28's Avatar
Car: 91 CAMARO Z28
Transmission: 700 R4 (CORVET SEVERO)
I HAVEING THE SAME PROMBLE
SOME ONE HELP ME!!!!!!!!!!!!!!!! MY 91 Z28 IS DOING THE SAME THING BUT I HAVE A NEW ING AND KEY TELL ME WHAT I HAVE TO DO NEXT. THE ING IS THE SAME ONE THAT COMES WITH THE CAR STOCK BUT IT IS A NEW ONE NOW IT WAS DOING IT BEFORE I CHINGEED IT AND IT STELL DOES IT NOW . SOME TIMES IT STARTS AND SOME TIME IT DONT IT IS GETING OLD NO ONE CAN HELP ME SO FOR MAYBE YAL CAN. SEND ME A REPLY OR CALL ME AT( 832) 385-6686 ANY TIME .THANK YOU FOR ALL YALLS HELP
Old Jun 10, 2006 | 02:18 PM
markymarco's Avatar
So like i said my dad and i bought the new ignition cylinder that turned out to be the problem becuase as you turn your key in the ignition their are 2 wires that hook up and turn inside their casing and sometimes break that was what was wrong with my dads car
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
