First Datalog, Help Analyzing.
Old Aug 31, 2006 | 05:54 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
SYMPTOMS:
Well as some may have read before, I was having issues with my car running very poorly after a Comp XR270HR-10 and Brodix IK200 Head swap on my 350 Speed Density TPI. I also had PCMforless burn me a chip.
I am getting poor idle, stalling, missing, backfiring, shuddering, hesitating, bogging, no power at all. So I adjusted the IAC and TPS to spec, and they are both in order. I am getting a code thrown at me as soon as the car starts up, but when I jump the ALDL connector A to B, I get no error code. I have checked, rechecked and rechecked vacuum line routing and quality, everything is perfect. I got new plug wires and are routed away from the headers, no burn-through. I also statically relashed the valves, and they are spot on.
DATALOG
Here is my datalog, it's a little over a minute long, and I had the counting at 10 counts per second. If it's too long, I can redo another log with less counts:
http://www.showsinyourtown.com/Test2.xls
I idled for a while, revved to 3-4k, idled, and back to 3-4k, idled and cut it. I was holding an idle to 1200-1500rpm because it wont hold on its own. It went into closed loop at around one minute.
There are some values that I am unfamiliar with, but things such as TPS, Spark Advance, A/F ratio, ect all look in order to me. What do you guys think?
Old Sep 2, 2006 | 10:29 PM
Well I got a better datalog for you guys. This one is of me starting up and driving around my block. (Less record counts this time, should be easy to read =]) Let me know if I left out any really important info this time...I tryed to cut down on things that I knew were sending back a null signal, or I knew didnt pertain to my issue.
http://eden.rutgers.edu/~irocz28/Test3.xls
As for the Coolant Temp: The sensor is not installed, I still need to find a place to put it since my new heads dont have provisions for it.
And the DTC error is just VATS acting up.
Old Sep 3, 2006 | 08:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Your best bet is to send the data logs to Alvin. Even if I tell you what is wrong you can't correct it.
RBob.
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
ezobens
Aug 19, 2015 10:29 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
