Accel ECU + msd box?
Old Sep 8, 2006 | 01:59 AM
1fast97gsx's Avatar
My car has an accel computer in it with an aftermarket wiring harness. The computer puts out the coil signals and runs straight to the coil to get primary igntion. I'm trying to run a msd 6 plus box on top of this so I have the nitrous timing retard function which I can have turn on if I arm the system and go wot.
The msd box has either pickup coil inputs, or a white wire which the instruction manual for the box says is to connect to breaker points, electronic ignition amplifier output, or to the yellow wire of an msd timing accessory. I'm assuming the msd box can't be used on top of the computer I have since I can't run the coil + - wires from the computer to the pickup coil inputs on the box, and the white wire is only a single wire. Any help would be greatly appreciated.
Old Sep 9, 2006 | 11:44 AM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
Take a look at this site. There might be some info for you
Ignition Control with MegaSquirt-II
Old Sep 11, 2006 | 12:44 PM
FASTR's Avatar
Car: 03 Evolution - 89 Iroc-Z
Engine: 383
Transmission: Art Carr 700R4
Which year car do you have? Which distributor do you have (the dual connector TPI style?)
Old Sep 20, 2006 | 10:43 PM
1fast97gsx's Avatar
Yea I have the dual connector style. Car is a 1992. I'm in the middle of rewiring the car so I want to do it all right. The coil gets it's signal from the 2 wire plug on the ignition module. Is there a way to route that plug to the msd box, then to the coil?
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
codeysabatini
Nov 10, 2015 04:07 PM
sreZ28
Oct 22, 2015 08:21 AM
WejaZ28
Oct 3, 2015 07:38 PM
86CamaroDan
Sep 29, 2015 10:08 PM
