Timing?
Old Sep 23, 2006 | 11:45 PM
Drac0nic's Avatar
Timing?
I've got a Megasquirt II I'm putting on a pretty much stock 4.3L V6, it's a TBI motor with swirlies. It's a stock type rebuild, not sure what's in the motor but it may be .030 over. I was wondering how much timing I should have at higher RPM and 100kpa, I was thinking in the last box (3100 RPM/100KPA) I should be putting about 28 degrees in (distributor set at 0 base) Am I on the right track with this or am I way off base. The whole idea of how to set up timing initially is a bit confusing to me. If anyone out there has an L05 how much timing are you running total at WOT?
Old Sep 24, 2006 | 12:09 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Here is my spark timing table. Add 2* in PE/WOT mode. I also have Coolant and IAT compensation. The hotter the engine gets, the less advance it runs. At an ideal 180* CTS and 70* IAT, it is 28* @ 2,800 rpm.
Attached Thumbnails Timing?-l05-timing.jpg   Timing?-ebl-timing-1.jpg   Timing?-ebl-timing-2.jpg
Old Oct 22, 2006 | 12:45 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
FAST355, what datalog software is that? Where can I get it?
Old Oct 23, 2006 | 01:33 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The HUD is part of RBob's EBL for TBI based engines.
DynamicEFI
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
