92-3.1 .Bin & .ADS for TunerPro Rt
Old Nov 7, 2006 | 10:11 AM
spoolingturbo6's Avatar
Has anyone developed an ads file for the 92-3.1 ECM? I'm using TunerPro Rt for a 7749 ECM in a forced induction motor.I like the layout of TunerPro Rt and would like to stick with it for the 3.1
I've bought an emulator ( Ostrich ) and OBD1 ALDL-USB cable.So I think I could use it a 3.1 if I had an ADS file and stock .Bin
Old Nov 8, 2006 | 07:01 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The latest stock auto BIN is AZTY, which is all over the net. BAWX is the latest stick BIN, which IIRC is around, but not as far spread. For .ADS file:
File Manager - Browsing directory /4) Datastream Definitions/
Worth looking at the fileman area for other good stuff.
RBob.
Old Nov 8, 2006 | 04:23 PM
Is the stock ECM a 1227730 for a 92 3.1 ?
Old Nov 8, 2006 | 09:04 PM
daves12secV6's Avatar
it has a diff number,but its just a renamed 730 ecm
Old Nov 13, 2006 | 01:22 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
I have tried every ads file that even comes close... with no success. I can get connected to the ecm but I can't get the data. I have read some OLD posts in the V6 board of some people making it work... but I haven't had any success (yet)
The Mode 01 request that gets me connected is F0, 56, 01 but I don't get data. I would also like to find the cross reference document between the bin and the aldl datastream.
I'll keep you posted if I find a solution. Please let us know if you come up with one. Thanks
Old May 5, 2010 | 02:38 PM
Re: 92-3.1 .Bin & .ADS for TunerPro Rt
I can't even find one close for a stock 92 camoaro 3.1 v6 auto.
Did you have any luck ?
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
ULTM8Z
Oct 2, 2015 01:25 PM
tmellott89
Aug 16, 2015 02:58 PM
