DFI 6.32 connectivity?
Old Nov 11, 2006 | 09:56 AM
honkeytonk_man's Avatar
Car: 1988 IROC-Z
Engine: e-tec headed ZZ-4 350
Transmission: t56
Axle/Gears: 9 bolt 3.7 posi
Hey Guys-
I tried to hook up my laptop to my ecm today for the first time. I have calmap 6.32 installed and I got the following message:
16 bit ms-dos subsystem
c:\calmap\calmap.exe
The system cannot open com1 port requested byt the application. Choose 'close to terminate the application.
So whats up? Is my laptop to new (it a year old Vaio). Am I overlooking something. Ecm was powered up but not running. Software booted Okay. Is there anything I can try? Do I needan oldere laptop. If so anyone got one for sale?
Thanks guys
Old Nov 13, 2006 | 06:36 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
The old 6.0 stuff needs to be run in a pure DOS environment. Nothing later than windoze 95 will really allow calmap 6.32 to work correctly. If you can find a copy of MS-DOS 6.22, and you can install that on your laptop, then rebooting the computer into DOS mode should work. Otherwise, your options with that laptop are pretty limited.
Old Dec 20, 2006 | 07:20 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Does your lap top have a serial port or are you running through a USB port? I had to change the port # for the USB port to COM1 in its properties. Got the com port to work but getting display candy striping.
Old Dec 21, 2006 | 07:10 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
Wow. That pic is pretty crazy.
What computer/operating system combo are you running to get that to happen?
The fact that you mentioned a USB port scares me a little. Unless you can get DOS drivers for a USB port (they probably don't exist) I don't think you are going to be able to run the old 6.0 stuff on your current laptop. I'm pretty sure you MUST have a true serial port on your computer to have any prayer of making that stuff work.
Old Dec 22, 2006 | 01:23 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Got a usb to serial adaptor cable at Radio Shack (http://www.radioshack.com/product/in...entPage=search) since the laptop does not have a serial port, once I got the port # correct it communicates with the on board computer, just have that crazy striping. I am running Xp on both my Dell desktop and Gateway laptop, runs fine on the desktop. Mirrored every setting I can find between the 2 with no luck.
Old Dec 23, 2006 | 01:58 PM
aDFIguy's Avatar
Car: GTP
Engine: L67
Hmm. That's pretty interesting about the usb adapter. Maybe try changing the resolution if you are getting in through a dos window. Otherwise, I'm not sure how to change the resolution if you are rebooting in dos mode.
InfernalVortex
Apr 20, 2021 11:31 AM
Gordonr1973
Sep 29, 2015 11:59 AM
efiguy
Sep 27, 2015 01:30 PM
