boost friendly timming curve??? :megasquirt
Old Apr 30, 2007 | 12:32 PM
daves12secV6's Avatar
anyone have a base timing map that is boost friendly that i can use
Old May 3, 2007 | 09:50 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Re: boost friendly timming curve??? :megasquirt
I would check the Megasquirt forums. They have a lot of experiance with custom setups and boost. From your title, I'm assuming you have a Megasquirt of some sort.
Megasquirt forums
I have never boosted an engine, however from what I've read, you really only need to pull timing in the fashion of "x degrees for every 1 psi" or something close to that. Sorry, don't have a clue as to what "x" might be, though.
Old May 3, 2007 | 10:14 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
hit up Jim on the msefi forum. He is very good at creating timing curves. Just give him your motor specs and he spits them right out.
He can also create AFR curves that are very good. If you have a wideband, that should be all you need to get it running again.
Did you get the 8-pin HEI to work with your timing correctly?
$750 L98
Feb 1, 2025 02:25 PM
Lbibb
May 5, 2016 12:00 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
ndndndnd
Sep 28, 2015 08:00 AM
