commander 950 & lc-1
Old May 9, 2007 | 09:40 PM
quix99's Avatar
Car: 1989 gta
Engine: 350 mini ram, zz9
i just put in a lc-1 with a commander 950 and the o2 reading is pinned at 10.0. even after calibrating, and switching base maps, one's even with 19 lb/hr injectors, the reading is still pinned at 10. the car has a zz9 cam, 24 lb/hr injectors, and dart 200 heads. and ideas? and yes its running rich and i dont want to blow out the rings, but the oil already has gas in it.
Old May 11, 2007 | 09:19 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: commander 950 & lc-1
Have you set up the outputs yet? I followed this and it fixed the problem. http://www.innovatemotorsports.com/r...mmander950.pdf
Old May 24, 2007 | 07:28 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
That will sure come in handy when I fire mine up. Thanks,
seiplentz
Aug 19, 2019 06:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
BBSDesigns
Sep 22, 2015 03:08 PM
rubyred88
Sep 17, 2015 02:19 PM
