what will happen
Old Jun 3, 2007 | 10:02 AM
surfertom's Avatar
Car: 86 Z-28
Transmission: 700-r4
what will happen
o.k. all this ecm stuff is new to me as i have always owned and worked on older chevys. i saved a 1986 z-28 from the crusher and am doing a frame up resto , got ahead of myself and ordered a stage 2 chip for a 305. after pulling the motor i discovered i had a 350 truck block one piece rear main with 305 heads. so after having a set of 350 heads built and completly rebuilding the motor i am wondering what will happen if i run the ecm #1227165 with the chip i bought or do i need to run a chip for a 350? tom
Old Jun 3, 2007 | 02:30 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: what will happen
even though the MAF systems are much more forgiving as far as mods go, it will probably be lean & will probably ping badly. you need to get a chip for a 350.
if you can, get your money back on the chip, they will never get it right.
for about the same price as the chip you bought, you can get the stuff to burn your own chips & get a much better tune.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
