1st generation ECM. Need a hand.
Old Jul 17, 2007 | 03:21 PM
ColdGTA's Avatar
Car: 1988 GTA
Engine: 5.7L stock
Ok working on my 81 Turbo T/A. The ecm seems to be acting up or going bad after going through a slew of performance checks in my service manual. I just want to make sure. It has the classic symptom with no clicking from the M/C soleniod. Second when I ground the terminals I don't get a get 12. I have checked all of the wires to the ecm and the grounds and the are all getting power where they should be and with the proper voltage. I do haowever get a strange code sequence when the terminal are grounded. With the light blinking I get a numaric sequence that goes like this:
1-11
1-111
1-1111
1-11111
11-11
11-111
11-1111
11-11111
111-11
111-111
111-1111
111-11111
ETC... just keeps going like that.
Hoking up my scanner for codes it just seems to blip through them all. So my guess would be that the ecm is done. Any thoughts?
Old Jul 18, 2007 | 07:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 1st generation ECM. Need a hand.
It surely doesn't look good. Clear the codes by pulling the fuse or battery negative cable for about 10 seconds. Then re-check for codes. Also check the ECM harness grounds on the engine block. A ground issue will cause goofy things to happen.
RBob.
Old Jul 19, 2007 | 02:47 AM
ColdGTA's Avatar
Car: 1988 GTA
Engine: 5.7L stock
RBob.
Thanks Rob that code sequence was before and after I unhooked the battery over night. Grounds all check out. It's always the first thing I check. I just hope it's not the prom. They are very hard to come by. Any other sites that might me more in tune with the first gen ECM??
db057
Apr 28, 2019 07:45 AM
Linson
Oct 1, 2015 09:50 PM
gord327
Sep 29, 2015 10:18 PM
scottmoyer
Sep 7, 2015 07:06 PM
