Will a 1227165 ECM in an '89 L98 correctly time injector
pulses for use with a cam that has the 7 and 4 lobes swapped?
My vote is that it will.pulses for use with a cam that has the 7 and 4 lobes swapped?
Cylinder location:
2 - 4 - 6 - 8 Chevy
1 - 3 - 5 - 7
Firing order:
1-8-4-3-6-5-7-2 Chevy (OEM)
1-8-7-3-6-5-4-2 Chevy (7/4 Swap)
Summarized from 'Corvette Fuel Injection' Probst, Charles O.
Bentley Publishers, ISBN 0-8376-0861-9
The L98 uses an electronically controlled HEI distributor.
Instead of weights, springs and vacuum; Electronic Spark
Timing (EST) controls spark advance. The rotor, cap and
wiring routing determine which plug is fired by the secondary
windings of the coil-in-cap.
As for the injectors on the L98
"For every two revolutions of the crankshaft, each gang of
four injectors opens and closes twice, alternating left
bank (four cylinders), right bank (four cylinders). GM
-speak: "Double-Fire
Comments, opinions, links to previous threads?four injectors opens and closes twice, alternating left
You are correct as to the 7/4 swap not being affected by the injection timing, or vice versa.
However, Probst, Charles O., is incorrect. The '165 & '7730 ECMs only have 1 injector driver in them. All 8 injectors fire at the same time. Double fire is when they fire once per revolution (double pulse per intake stroke per cylinder), and single fire is when they fire once every 2 revolutions (single pulse per intake stroke per cylinder).
RBob.
RBob.
wow so we're leaving even more on the table vs sequential then i thought. im surprised we don't have more fuel puddling issues, 8 injector batch fire must leave some fuel waiting for awhille.
Fast355
close
- Join DateJan 2005
- LocationHurst, Texas
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car1983 G20 Chevy
- Engine305 TPI
- Transmission4L60
- Axle/Gears14 bolt with 3.07 gears
- Liked:508 Times in 436 Posts
Quote:
I run my V6 MPFI setup on a 4.3 CPI PCM and the $0D code.Originally Posted by rockit
wow so we're leaving even more on the table vs sequential then i thought. im surprised we don't have more fuel puddling issues, 8 injector batch fire must leave some fuel waiting for awhille. Senior Member
i need a translation fast355 dunno what you're getting at. but this thread got me thinking about the pcm you're using in your van, could we not easily apply it to a MAF 5.7 l98 with a map sensor attached? sounds easier then to do it on tbi!
dunno what kind of epuipment it has injector driver wise but i remember reading that it had batch and sequential fire (for 8 injectors?) and that it is still obd1, what do you think?
Bump
