ECM does not go into diagnosis.
I jumper the A?B terminals on the 88 305 TPI Trans AM and rather than the system going into diagnosis mode and flashing any codes the primary cooling air fan goes on. Help.
I tried to check the ECM for power, I think it is the Black plastic AC box 4"x 5" under the passenger side dash panel, with about 10 wire connections. I find 4- 5 V power on some of the leads.
Any idea how to get a wiring diagram the one in the Chilton's book doesn't cover it.
Car: check
Engine: check
Transmission: check
Re: ECM does not go into diagnosis.
The 4x5" AC box is most likely the cruise control module. The ECM is the larger silver aluminum case.
For wiring go over to the diy-efi.org site, GMECM, under ECMS. Stock your ECM will be the 1227165.
RBob.
RBob.
efiguy
Sep 27, 2015 01:30 PM
