EBL users
Old Nov 20, 2007 | 06:06 PM
cranknrods's Avatar
Car: 92 RS
Engine: 350vortec
EBL users
how many of you guys running EBL are using a WB02 sensor?
thats just one of my curiosity questions-im looking at getting a wb so i thought id see what wb sensors you guys are running-im kindof a carb guy trying to expand my horizons so if this is a dumb question i apologize.
also-correct me if im wrong but my understanding of the VE learn function is that when the VE screen shows a "-1" somewhere the ecm then adjust injector pulse width at that rpm X map area. it subtracts 1% of fuel at that load range.
what else does it adjust?
if you have a linky to some good reading matterial on this, that would be great
thanks guys ---a little bit longer messin with this thing and i think i will be doin pretty good
the cars already running really good-i just need more knowledge and tinker time so i can get it smoothed out.
Old Nov 21, 2007 | 04:10 PM
Ronny's Avatar
Re: EBL users
[QUOTE=cranknrods;3539313]
My understanding is that VE learn provides you with a corrected .bin from an EBL datalog as far as fueling tables(lower-upper) are concerned. You still need to drop that .bin into your cars ECU. That is using NB02 feedback in closed loop. you can also use the WB02 in OL to achive corrections(VE Learn). That is the preferred method.
Old Nov 22, 2007 | 02:01 AM
cranknrods's Avatar
Car: 92 RS
Engine: 350vortec
Re: EBL users
yeah ronny thats what i have been doing-its a great function except that by the end of the day (after alot of tuning) i find myself flashing the ecu with a bin named "somthingorother_new_new_new_new_new_new_new_new.bin". not that im complaining, i just get so caught up in tuning that i dont get around to organizing my bin file.
im really interested in finding out what WB02 sensor and controller other EBL user have----is a controller even required?.....
thanks for clarifying
Old Nov 22, 2007 | 08:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL users
Originally Posted by cranknrods
. . . I find myself flashing the ecu with a bin named "somthingorother_new_new_new_new_new_new_new_new.bin". . . .
This is actually changing. A new version of the WUD reads the PromID from the current BIN, increments it, and uses it as that part of the new BIN filename. It also updates the new BIN's PromId to match. Much cleaner way of doing it.
Keep an eye on the web site there will soon be an announcement of the release. Which will be available to all EBL users via an email request. Also added a knock alert sound feature, and some other odds & ends.
For a WB, will need a controller.
RBob.
Old Nov 22, 2007 | 08:38 AM
gofast51's Avatar
Re: EBL users
You can also rename the file. For instance I name mine EBL1.bin then EBL2.bin, much easier to contend with. Whatever works for you!!!
Old Nov 22, 2007 | 01:59 PM
Pre-Tuner's Avatar
Car: '91 Chevy 1500
Re: EBL users
I run a WB with the EBL. Those are the two best tuning investments I have made. They are both amazing. The learn function takes a lot of the headaches away too.
I'd like to put my glovebox back in, so I may be upgrading to the flash EBL sometime. I haven't even had the EBL a year yet, so it's hard to justify the cost at this point.
Old Nov 24, 2007 | 06:46 AM
cranknrods's Avatar
Car: 92 RS
Engine: 350vortec
Re: EBL users
what WB02 controller do you guys recommend-you know the gig "best bang for the buck"
RBOB-i look forward to the updates-i will have to keep an eye out for them
thanks for the loads of info guys
pre-tuner--i havent ever had to actually burn chips but i would imagine that the EBL flash is a whole lot less time consuming-last week i burned 3 different bins all in one car ride-that would have been really hard to do if i didnt have the EBL flash
i just open the bin im using-mod the SA table(or whatever) and flash it-then good to go
Old Nov 26, 2007 | 09:15 PM
91chevz71's Avatar
Re: EBL users
I use the Zeitonix ZT-2 with the Flash EBL w/o issue.
works great
Old Nov 27, 2007 | 08:11 PM
Mike Delisi's Avatar
Re: EBL users
I just bought the ebl classic. it came with the telephone like cable and an adapter for the serial port but my laptop has no serial port access. any suggestions??
Old Nov 27, 2007 | 08:14 PM
Pre-Tuner's Avatar
Car: '91 Chevy 1500
Re: EBL users
You'll need an adapter. The one I used to use was a Belkin adapter, but you have to have a USB port.
Old Nov 28, 2007 | 10:02 AM
Ronny's Avatar
Re: EBL users
i thnk most any serial/usb adapter will work. i used a radio shack as well as another adapter. no issues. the usb to parallel was a bitch.
Old Nov 28, 2007 | 02:52 PM
galvarado's Avatar
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
Re: EBL users
I've been using the EBL with an LM-1 for over two years now. I love the EBL along with the WB02. I've gotten comfortable enough with it that I'm going to attempt to tune a 383.
Gene
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
92rsvortec350
Sep 16, 2015 09:12 AM
85Special
Sep 3, 2015 04:21 PM
