How to test mass air
Old Dec 5, 2007 | 11:46 AM
mustang1994bob's Avatar
How to test mass air?
89 tpi 350 is running very very rich, im testing sensors, the tps was off so I adjusted it to .5 at zero throttle, next I went to the maf and im not sure how to test, and also it has a crack where the inner tube connects to the rest to the unit. so I need some solid test procedures and them opinion on the crack.
one more thing, I need a how to to test o2 sensors. thanks.
Old Dec 5, 2007 | 12:07 PM
Stephen's Avatar
Car: 87 GTA
Re: How to test mass air
I've been wondering the same thing. I've got a spare MAF, and believe it to be good, but I wanna KNOW if it is good or not.
Old Dec 5, 2007 | 07:18 PM
no one knows??? Its just a mater of which wire is hot, which one is ref. ect.(I just dont want to fry it but poking around and hopping) So you all just replace them and hope your $200 guess was the right one??
Old Dec 5, 2007 | 07:46 PM
Stephen's Avatar
Car: 87 GTA
I'll ask my OPEG, It hasn't been a priority for me, so I haven't bothered to ask him.
Old Dec 5, 2007 | 08:20 PM
thanks, that would be great, I've got too limited of a budget to just guess
Old Dec 5, 2007 | 09:05 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
you need a profressional scope, very expensive. most good shops have them
Old Dec 6, 2007 | 10:20 AM
Stephen's Avatar
Car: 87 GTA
OPEG says jayk2k3 is right. No easy/cheap/un-complicated way to test a MAF.
If you've got a MAF buddy, swap MAFs with him, to test & eliminate it.
Old Dec 6, 2007 | 10:30 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
OPEG here.
This thread has some answers but beware, the tests are nothing but simple "does-it-even-work" tests. They won't tell you how precise the MAF output is, they'll just tell you if it works or not.
https://www.thirdgen.org/forums/v6/3...-test-maf.html
If you have some local 3rdgen buddies, you can borrow a MAF from them for 5 minutes and see if that fixes your problem. If not, it's not likely the MAF.
On a side note, a rich running condition can be caused by multiple factors. The CTS may be disonnected (bad wiring) or read maybe -20F, the injectors might be flowing at different rates (been there), the IAT may be reading way low too ... as I said, multiple factors. It would help to hookup a laptop to it to see what the ECM sees and does.
Hope this helps.
Lou
Old Dec 6, 2007 | 03:20 PM
Thanks, this helps, and Ive checked all the other stuff, this was just the last thing, im a test first kinda guy. maf is bad btw
Old Dec 7, 2007 | 12:26 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
A DMM (anything with voltage and a frequency counter) and a typical MAF table off the 'net can be used to diagnose just about all of GMs MAFs. Typically at idle you should see around 6-8 grams per second of airflow for a V8.
Old Dec 9, 2007 | 12:25 AM
Stephen's Avatar
Car: 87 GTA
And we count grams per second how....at home?
Old Dec 10, 2007 | 08:52 AM
BigBadLou's Avatar
Engine: TPI
You would use those MAF tables off the internet (mentioned above) and calculate what airflow specific voltage translates to.
Lou
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Thornburg
Aug 27, 2015 08:28 PM
chazman
Aug 22, 2015 02:01 PM
