What's needed for info with laptop
Old Feb 1, 2008 | 09:13 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
I just got a new laptop with Windows Vista. I am new to this & would like to know what I need as far as cords & programs to read & clear codes. I would also like the capability to view engine info like TPS volts. I might even get into burning proms but that will be later since it seems pretty complicated, right now just the reading diagnostic info would be good & if I could record it even better. I would appreciate any help anyone can give me. Thanks
Old Feb 6, 2008 | 11:19 AM
Ronny's Avatar
Re: What's needed for info with laptop
Vista may be a no go. search "vista". i bought lappy with vista. ended up uninstal and added XP. then i created a parallel port with a pcmia card and used a serial to usb as well. now all is ok. i would return it and buy a lappy with xp on it. IMHO.
Old Feb 6, 2008 | 12:59 PM
AMigs87IROCz's Avatar
Car: 1987 Iroc-z
Engine: Swapped into a 350TPI
Transmission: T-56 Six Speed
Axle/Gears: Moser 12 Bolt 3:42 Gears
you need software(snap on, dfi, ect...) and the proper obd plug in, not sure where to get them, I'd check online...
Old Feb 7, 2008 | 09:04 AM
Ronny's Avatar
check stickies on DIY prom.
IROCZ1989
Jan 24, 2016 03:55 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
