Getin Boosted, now what???
Old Mar 1, 2008 | 04:07 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Ok, 91 Firebird TPI 5.0 5 Speed with D1SC 3 core Procharger, 4.75" Pulley (8 to 9 PSI rated for 350)...
I'm building a Knight Rider replica and electronic gauges run off factory wires...
I want to run this low boost for now and later, when I get a new / bigger engine, then really turn up the boost... so expandability is also key...
What kind of system do you think I should go with???
I'm looking at repinning my 730 to 749, Running Ostrich Emu and code59 so ecm can monitor boost etc... to get all the parts are about $1000 or so...
EBL: won't work with my ecm, but I think switching and repinning to another ecm and adding few things, I can use it. I know it has an auto tune feature (I think code59 does to, but not quite as built in) but is limited to 15lbs boost (code 59 can use 3 bar, 30 psi)...
Mega Squirt??? will this let me keep my stock ecu too?
XFI, anything else?
I'm looking at ease of use / setup / cost and how well they work... Again, i'm leaning toward the code59 since I'll probably need new injecotors besides the 19lbs ones that are stock...
Any opinions welcome...
Thanks,
Rafael
$750 L98
Feb 1, 2025 02:25 PM
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
