SES Issues, may be bad computer?
Car: 1985 IROC
Engine: 305 4bbl H.O.
Transmission: WC T-5
My MCS pigtail broke where the plastic surrounds the metal connectors. I purchased a new pigtail and wired it in. The MCS will not click, however the engine starts and runs fine. I have a constant SES light.
I tried to pull the trouble codes, but the SES light won't flash anything, not even 12. I went to the store and purchased their OBD I tester thinking that I wasn't making a good connection with my jumper wire. Code 12 wouldn't flash then either.
Could this be a bad ECM?
Car: 1985 IROC
Re: SES Issues, may be bad computer?
the connector that connects the mixture control solenoid in the carburator to the wiring harness.
Car: 1985 IROC
No, I mean the SES doesn't even flash 12. It is on steady when jumped at the terminal, or while the engine is running.
eightsixseven
Dec 16, 2024 01:50 PM
