87 l98 datastram numbers..I have some questions.
Old Jul 8, 2008 | 03:56 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
so i just hooked up a scan tool to my 87 iroc l98 and just curious about a couple of the numbers i got.
128 blm at idle which is good ive heard
when crusing it was around 137 and wot was 139.
are these good numbers?
and also right around 3700-4000rpm each wot shift i would get knock retard just for a second ranging from about 5-11 was the peek retard.
is this normal? i dont feel any power loss and its just for a breift second it dosent keep retarding.
thanks
Old Jul 9, 2008 | 02:34 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: 87 l98 datastram numbers..I have some questions.
Normal,
you may want to check for worn bushings to make some of the KR go away.
Old Jul 9, 2008 | 02:45 AM
Car: 89 Iroc
Engine: 5.7 TPI
ok so gettin knock for a breif second at wot is normal?
and bushings your talking? motor mounts control arms pretty much everything?
also i have hooker super comp headers and 3 inch hooker exhaust.
but i think if i was gettin an actual false knock from headers it wouldnt be so breif?
91chevyz28
Feb 10, 2022 07:58 PM
FormulasOnly
Jul 23, 2018 08:47 AM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
