Gen7 datalog question
Old Aug 1, 2008 | 03:39 PM
weez58's Avatar
Car: 70 vette roadster
Engine: 383
Transmission: tremec 5spd
Question for the Gen 7 people,
I'm looking at my datalog graphs and I'm trying to figure out what the O2 feedback value would be if the actual AFR is equal to the AFR value in the table. The numbers I'm seeing range from .93 to 1.08. Does 1.00 mean no fuel is being added or subtracted? Do numbers above 1.00 mean fuel is being added and if the number is less than 1.00 then fuel is being subtracted?
Thanks,
Bob
Old Aug 5, 2008 | 08:16 AM
388's Avatar
388
Car: oldsmobile
Engine: 3.88
Transmission: yes
Axle/Gears: yes it has axles
Re: Gen7 datalog question
Yes Bob you are correct. Think of the # as a correction factor.1.0 means there is no correction needed to hit the target afr.
CORV3TT3
Aug 23, 2015 11:26 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
