350 ecu
Old Sep 1, 2008 | 07:49 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
350 ecu
ok heres the problem i have a 350 in the t/a but the ecu is a 305 ecu and i was wondering if i could just put in a c4 corvette ecu and it just plug right in or would it not work
Old Sep 11, 2008 | 07:26 PM
87transGTA's Avatar
Car: 87 GTA
Re: 350 ecu
anyone???
Old Sep 11, 2008 | 08:59 PM
Railguy's Avatar
Car: 87 GTA
Engine: 5.0 LB9
Transmission: 700-r
Re: 350 ecu
im guessing its a 165 and no you dont have too replace the whole computer just the chip/memcal its not real hard theres a few that do it here , they use a moates adapter its easy and painless harris is the guys last name i think one of the moderators can expound on it im not real sure of the sponsors here as im sorta new too the forums but you can get a custom chip no probs for real
regards rail
Last edited by Railguy; Sep 11, 2008 at 09:22 PM. Reason: cause i cant freaking spelll
Old Sep 12, 2008 | 01:42 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 350 ecu
The computers are the same for both 305 TPI and 350 TPI. Its the chip, memcal, or PROM that is different. Is the car running bad right now? What you need is a "custom chip" either done by yourself, a local shop, or one of the internet tuners.
Old Sep 12, 2008 | 11:30 AM
87transGTA's Avatar
Car: 87 GTA
Re: 350 ecu
it runs alright but ocasionally it will feel like its boged down and idles weird at times and when the engine gets up to temp its hard to crank up
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
88rscamar0
Sep 23, 2015 09:08 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
