7730 ESC Self Test- how does this work?
Old Sep 7, 2008 | 12:06 PM
DarkShark's Avatar
Car: C3
Engine: GMPP w/TPI
Transmission: TH350
Hi-
I have a code 43 and I believe that my timing is so retarded that the self test is failing. I have it set to 6 degrees BTDC- stock TPI motors usually call for 6 degrees. I have a different engine though. I've seen in various posts from various forums that many folks have experienced success with 10-12 degrees of advance for a carbed set up for the GMPP 12499529 engine.
Can anyone describe how the self test actually works? If memory serves me, I think the ECM advances the timing until it gets a knock- then, it sets it back- all as part of the process to determine if the ESC circuit is working. If my timing is too far retarded, I feel it is likely that I'll never get detonation on a 8.5 squeeze motor within the 20 degree parameters for ECM advance.
Thoughts?
I have a 7730 TPI system on a GMPP 12499529 engine with 1.6 rollers, SLP runners, and 24lb injectors.
Old Sep 7, 2008 | 01:06 PM
DarkShark's Avatar
Car: C3
Engine: GMPP w/TPI
Transmission: TH350
Re: 7730 ESC Self Test- how does this work?
I found a post where RBob explained the self test at a high level.
FWIW... my knock sensor checks out in terms of GM service procedure ohms, #496 checks out for voltage.
If I clear the codes... the light stays off for anywhere from 10 (warm) seconds to 2 minutes (cold). I believe that is related to the self test.
I'm going to set the base timing to between 10-12 degrees and see what happens. I've heard that my engine seems to like a lot of advance to compensate for low compression and a (relatively) big cam.
Old Sep 7, 2008 | 03:01 PM
DarkShark's Avatar
Car: C3
Engine: GMPP w/TPI
Transmission: TH350
Timing set to 12 BTDC, new knock sensor, new ECM... no code 43!!!!
Old Sep 7, 2008 | 07:16 PM
ultimatefighter's Avatar
Car: 1992 Z28
Axle/Gears: 10 bolt posi. G80
Cool. Don't mean to hijack. But, for a new ECM, did you have to replace the whole ECU? Is yours on the MEMCAL in the ECU?
Thanks, hope all is working good.
Old Sep 7, 2008 | 10:44 PM
DarkShark's Avatar
Car: C3
Engine: GMPP w/TPI
Transmission: TH350
Memcal was okay... PCM for less programmed the MEMCAL.
The ECM itself was bought used off ebay. I had no guarantee on the ECM. Really, I figured it would go out sometime and I'd replace it with one that had a waranty. I bought that ECM a year ago.
Old Sep 9, 2008 | 06:11 PM
DarkShark's Avatar
Car: C3
Engine: GMPP w/TPI
Transmission: TH350
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
