ecm swap
Old Nov 12, 2008 | 10:11 AM
dallasj's Avatar
ecm swap
i have an 82 camaro stock all original with cfi. The tb on the drivers side works fine but the passengers side has nothing, i swap the connectors it works perfect, so i know the injector works. Move down to the ecm swap the wires there and that seems to be where my problem is. I ran a test lead form the ecm (hooked a long piece of wire to the injector 2 wire) and plugged it into the injector still nothing, thought i might have had a short in the original wiring, both fuses are good. No cel that i can see, it just seems that the ecm is bad, i guess.
Question is what do i do should i swap the ecm or is it something simple?
I found an ecm from a vette the number is 1226026 will it work in my car, my ecm is the 1225550.
Stock 305cfi, automatic tranny, please someone help me
Old Nov 12, 2008 | 03:18 PM
Ronny's Avatar
Re: ecm swap
If the 6026 is from a CF vette I dont see why not. remember to swap the chip and same on calpack. Yours are way diff.
Old Nov 12, 2008 | 04:46 PM
dallasj's Avatar
Re: ecm swap
where is the chip at? This cfi stuff is all new to me and i dont understand it at all yet im a carb type person
Old Nov 12, 2008 | 05:01 PM
Ronny's Avatar
Re: ecm swap
remove the inspection cover. It is like 2 inch x 4 inch. there is a chip and a calpack(smaller chip) under cover. Note direction-orientation. Be very careful when removing and more so reinserting. There might be a plastic "keeper" over chip that may have to be carefully removed. Been a while since I did so. Might be photos on crossfire forum or here in DIY-Prom. Instruction to remove may be on hypertech site as well.
Old Nov 12, 2008 | 05:04 PM
dallasj's Avatar
Re: ecm swap
what inspection cover, might i also add this my first f-body, i had nothing but 80 model chevy trucks swb, so im lost on this car in general, im just trying to get it running right till i can engine swap it
Old Nov 13, 2008 | 09:50 AM
Ronny's Avatar
Re: ecm swap
The ECU is under dash at passanger area I believe. the ECU has a small access panel to remove chip as I described.
AussiePr0nCar
Mar 6, 2020 04:04 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
