91 camaro 3.1 runs good till warm
Old Nov 28, 2008 | 08:37 AM
amaraz's Avatar
Car: 92 camaro 25th anniversary
Engine: 3.1
Transmission: auto
car starts and runs good till warm,then sputters awhile then dies,won't start until it cools off. recently car would not run at all,found 5 month old converter clogged ,cut it out about a month ago and car ran until now.New O2 and CTS , I thought maybe ECM is bad, will ECM from 3.1 lumina work?
Old Nov 28, 2008 | 10:48 AM
project89's Avatar
Re: 91 camaro 3.1 runs good till warm
car have spark and fuel when it wont start.
no spark = more then likley it needs an ignition module
no fuel = more then likley fp or the fp relay is going bad
Old Nov 28, 2008 | 10:52 AM
amaraz's Avatar
Engine: 3.1
Transmission: auto
if module or relay is bad, what would cause new converter get plugged up?
Old Nov 28, 2008 | 05:35 PM
project89's Avatar
theres a few things that can cause that
running to lean,running way to rich, carbon etc
Old Nov 29, 2008 | 09:47 AM
amaraz's Avatar
Engine: 3.1
Transmission: auto
if module or relay is bad would I get afault code, I don't get any
Old Nov 29, 2008 | 11:17 AM
project89's Avatar
no u wouldnt get a code
Old Nov 30, 2008 | 03:09 PM
amaraz's Avatar
Engine: 3.1
Transmission: auto
The clogged cat and the not running might not be related,thanks I will check for fuel and spark. Would exhaust manifold leak cause bad reading from O2 causing rich condition and clogging cat?
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
the_nikfive
Aug 11, 2015 02:46 AM
mustangman65_79
Aug 8, 2015 12:07 PM
