Benefits of no ECM
Old Dec 5, 2008 | 09:39 PM
zevans08's Avatar
Benefits of no ECM
If I where to run a carb'd engine with a 5spd and remove the ECM would there be any beneits from removing the ECM?
Old Dec 5, 2008 | 10:14 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: Benefits of no ECM
Kind of a weird question... Do you mean that you would be running the carb'd/5spd setup, but leaving the ECM sitting there under the dash? Or, are you asking what the advantages are to running a carb'd/5spd setup as compared to an computer controlled setup?
Old Dec 9, 2008 | 02:27 PM
Ronny's Avatar
You then run old school distributor? weights and all? I say you should keep ECU control of spark. allows calibration of SA with a laptop assuming you wish to tweek it. MSD offers chips to offers differing curves in one of their Dizzy's. that beats disassembly.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
